Home etching would be fine.... that is what I did but its single sided only.... having the shield site in the top will allow for tighter RF control and less chance of frequency drift / spurious oscillations.. and from the price that he has for a double sided etched board you really cant go wrong. I etched because I was in the early development stages and didn't want to dump a lot of cash into it.
I followed all the instructions on his site including his procedure for tuning before I used any scope
or analyzer just to see if it can be done with out any special equipment. and you can i only used the
scope and spectrum to confirm... you have to be cautious, the second Harmonic of the FM dial is highly
used by aircraft.. make sure you enclose this puppy in a metal enclosure That is tied to the DC & RF ground.
The function of C17,L5,L4,C16,C10,L3 is its the low pass filter that is suppose to block all frequencies
above 108 Mhz from emanating from the transmitter.
Here is the BOM of parts I have purchased from mouser for this project, there are a few parts that have to be purchased from elsewhere..
Caps
80-C1206C103J5R Qty:12 Desc.: 1206 SMD Ceramic Cap 50volts 10000pF X7R 5%
140-100N2-150J-RC Qty:4 Desc.: Ceramic Disc Capacitors 100V 15pF NPO 5% Tol
140-50N5-330J-RC Qty:3 Desc.: Ceramic Disc Capacitors 50V 33pF NPO 5% Tol
140-50S5-331J-RC Qty:1 Desc.: Ceramic Disc Capacitors 50V 330pF SL 5% Tol
81-RPE5CA470J2P1Z03B Qty:1 Desc.: Monolithic Radial Lead Capacitors 47pF 100volts
59-GYC65000 Qty:1 Desc.: FILMTRIM Plastic Trimmer Capacitors 4.5-65pF 100V 10mm
647-UVR1E471MPD1TD Qty:1 Desc.: Electrolytic Capacitors - 85 Degree 470UF 25V
647-UVR1H100MDD1TD Qty:2 Desc.: Electrolytic Capacitors - 85 Degree 10uF 50V 20%
647-UVR1C101MDD1TD Qty:4 Desc.: Electrolytic Capacitors - 85 Degree 100UF 16V
647-USA1H4R7MDD Qty:1 Desc.: Electrolytic Capacitors - 85 Degree 4.7UF 50V
81-RPE5C1H220J1A1Y02 Qty:1 Desc.: Monolithic Radial Lead Capacitors 22pF 50volts
81-RPER71332K2P1A03B Qty:1 Desc.: Monolithic Radial Lead Capacitors 3300pF 50volts
581-SA105E104MAR Qty:2 Desc.: Axial Ceramic Capacitors 50volts 0.1uF 20% Z5U
581-AR211C103K4R Qty:1 Desc.: Monolithic Capacitors 100volts 0.01uF 10% X8R
Resistors
71-CCF07-G-10K QTY:6 Desc.: Metal Film Resistors 1/4watt 10Kohms
71-CCF07-G-33K QTY:2 Desc.: Metal Film Resistors 1/4watt 33Kohms
660-MF1/4LCT52R183Gt QTY:2 Desc.: Metal Film Resistors 1/4WATT 18KOHM
660-MF1/4LCT52R180J Qty:1 Desc.: Metal Film Resistors 1/4WATT 18OHM
660-RK73H2BTTD1003F Qty:1 Desc.: 1206 SMD Resistor 1/4watts 100Kohms 1%
660-MF1/4DCT52R33R0F Qty:1 Desc.: Metal Film Resistors 1/4W 33 ohm 1%
271-91-RC Qty:1 Desc.: 1/4W 1% Metal Film Resistors 91ohms
271-4.7K-RC Qty:1 Desc.: 1/4W 1% Metal Film Resistors 4.7Kohms
271-680-RC Qty:5 Desc.: 1/4W 1% Metal Film Resistors 680ohms
271-270-RC Qty:2 Desc.: 1/4W 1% Metal Film Resistors 270ohms
531-PT6KV-5K Qty:1 Desc.: Trimmer Potentiometers 5Kohms 6mm Rnd Top adj
Semi
63-MC78L09ACPG Qty:1 Desc.: Linear Regulators- 9V 100mA Postive
579-PIC16F627A-I/P Qty:1 Desc.: PIC16Fxxx Flash MCUs 1.75KB 224 RAM 16I/O
771-BBY40-T/R Qty:2 Desc.: Diodes - Variable Capacitance VHF VAR CAP 30V
512-BC547BU Qty:1 Desc.: Small Signal Transistors NPN Si Transistor Epitaxial
771-BFG135-T/R Qty:1 Desc.: RF Transistors NPN 150MA 15V 7GHZ
512-BF240 Qty:1 Desc.: Small Signal Transistors NPN RF Transistor
512-KA78L05AZTA Qty:1 Desc.: Linear Regulators- 5V 100mA Postive
Other
523-31-5431-10RFX Qty:3 Desc.: BNC RFX Connectors PC R/A BLHD JCK
511-1N5818 Qty:1 Desc.: Power Schottky Rectifiers Vr/30V Io/1A
70-IRF1-1.0 Qty:1 Desc.: High Current Inductors 1uH 10%
593-VAOL-5LSBY2 Qty:1 Desc.: LEDs Standard Blue Diffused 462nm 1500mcd
688-SKHHLM Qty:2 Desc.: Tactile Switches 6.0x6.0x3.85mm 100g
These parts have to be ordered from Futurelec
Futurlec
2N3553
crystal 3.2 MHz
These parts have to be found I had luck on ebay
TSA5511
TR1 - rf ferrite transformer
Amidon Corp BN-61-202 Wideband Multi Aperture Core , Unfortunately they have a 10.00 min order so if you are serious send me a pm, I have 3 extras I would send to 3 ppl. they were only 80 cents each
NOTE: IF you decide to only make this a 150mw transmitter these parts you will NOT need parts list according to pira website
http://pira.cz/entx4.htm
Q3: 2N3553 4W RF NPN
L2 - 1uH/815mA choke
C18 - trimmer 50p
R9 - 18 Ohms
L3 - 2.5 turns on 6 mm diameter (4.5 turns if Q3 is 2N3553)
This means the only hard to get parts you will need othr than from mouser will be the tsa5511 chip and either the 3.2 or 6.4 crystal
