My dad (in the picture) is 70 and we've built a ton of RGB props this year. Stick with it, we're here to help!
Thanks for the encouragement. I can do the building, I just can't do all the installing. Bad heart!
First of all, I started in Jan 2015 where you are now, at age 74, I am now 76 so age has nothing to do with it.
You may want to join the Xlights Forum as there are many there that will help you and as you can see you already have those here offering help. You can ask me by email if you wish or post on forums. The forums will give you more responses.
Don't' go back if you load version 39 as it is not backwards compatible like others have said look at the videos they will get you started and you do not have to use music to do effects, my show last year was only a two minute sequence repeated and it was fun to do and see. I have put a picture of just a shot of the sequence but the display was all I had time to build last year.
Kent
search for sean meighan on vimeo for videos. Set up your Universes I would use 510 per Universe not 512 as some controllers can not span the 511 and 512 without turning on the wrong lights. Then look for videos on how to set up using the newer version. It is really pretty straight forward. I am including a picture of the layout screen that you can see when you refer to the user manual. The symbols at the top allow you to create the model. BTW the Christmas Expo in Chicago this July there will be people from Xlights that can help you.
Kent
Fran I am using version at the moment 2016.37 however my video cards are not AMD nor my chips AMD some of the later versions are having a problem with these chip sets but they are getting worked out.
Xlights allows a capability of using layers and also displaying the entire House model. I have worked out my show and captured it on video from my monitor so here is a link if you want to see it.
https://www.youtube.com/watch?v=MdSFwOIuN2U&feature=youtu.be
Fran if you have questions about anything just ask, I use the Raspberry PI to run the show and my controllers are Falcon F16V2 that can run 680 Pixels per plug and have 16 plugs. You can search my posts on the Xlights Forum.
Hope this may help you.
Kent
Thanks for the info Kent.
I have 2016.39beta installed but can't find any info or vids telling how to use it. All the Youtubes I found were for an older version. I may fall back to the last non-beta version.
Thanks for you offer to help. I need all the help I can get. My wife tells me I'm too old (70) to be trying to do all this stuff. I have lots of physical restrictions too.
I am starting out with just two arches this year so I can get my head around all this stuff.
Should I post my questions for you here on the forum or direct to you via email?
