I made up some new videos for programming PICs. They are more detailed and narrated. They show downloading and working with the Renard firmware, and the flash software of the programmer.
With these videos, you will see that programming is a very simple task and something anyone can do. The videos are short and broke up into sections for quick reference. So.... here they are...............
First thing to do.....
Download and install MPLAB IDE software. (at the time of this edit, it is v8.92) MSASMWIN is bundled with MPLAB. Once done with the install, go to the program list and look for for the "Microchip" folder, MPASMWIN is in that folder.
If using a PicKit 2 programmer, you will need the PicKit 2 stand alone software used in the video, it can be downloaded here at the bottom of the page. V2.61 at the time of this edit. If you need info on setting up the PicKit 2 , Here is the User's Guide.
Now that you have the software done and the PicKit 2 setup, you can follow the videos.
Downloading the .asm file and using MPASMWIN software to create a .HEX file
**no link at this time
Program the PIC using PicKit 2 flash software and generated .HEX file.
****EDIT**** in the video, I instruct to set the programmer at 5V, I have found that 4.9V is more reliable.
New instructions for using the PicKit III by 'mmulvenna'
**** Notes... Links to these videos (and more info) can also be found in the Christmas Wiki : General Information and Tips ****
Okay folks here it is. Dont be too critical as I threw it together pretty fast. This is only to program the chip using the "HEX" file. The first few screens would be the same for the "ASM" file but then you should be able to use Waynes videos for the "project creation".
EDIT: You should also be able to use this for the diagnostic firmware, just change the file name that you select in the file browse.
Hope this helps... and good luck. Happy PICkiting
Old man Mike
http://doityourselfchristmas.com/forums/attachment.php?attachmentid=5924&d=1264521468
