Hey Ben,
I'd be interested in working with you on that project.
It looks that way, as far as MOSI and MISO, during the data transmisison portion.
I'm not sure what the distinction is really, isn't byte mode just a burst of length 1?
Update: A month or two ago I was running into some problems with the driver so I shelved the project. Two days ago I picked it back up I've been able to get the driver to function, or at least the early tests seem to prove that out. I plan to increase the overall driver speed next, optimize some of the code, and then I'll look into implementing burst mode (a new feature for this device).
What was the issue that you resolved?
I'm back to struggling with the speed. I'm tempted to post the slower functional version to google project site for people to use. Anyone interested in it?
Ben and Jim,
Is this module's pin-out the same as the 5100, so that Jim could be able to use the WS5200 to make the Web Server available full time on the E681 without hardware mods? Or are there also limitations to the Prop that prevent this possibility?
Just wondering...
Jeff
See post #2 - they are different footprints. Fortunately access to the web server is really not needed once it is set up. Is there some reason you would want it up full time?
...I still believe it should be available at all times...
I'm with you Ben. I don't look at it from the perspective of an end user... "once it's set up, it's not needed" I find myself constantly switching things around trying different arrangements. Being able to make changes quickly from a live webserver makes testing so much easier. Due to the fact that I'm still using LOR software along with Jim's ELOR, I chose to forgo using the forth Cluster in favor of the webserver. (The LOR network has bandwidth limitations that make using a full 680 pixels a bit of a challenge anyway)
Jeff
If you are doing live setup/testing just do "QUIT" and you'll have normal data access in 10 seconds. Yes - the extra socket would be better but again I don't see it as a big deal I guess... You almost certainly won't be making changes once your show is set up since even minor changes would disconnect pixel location to channels in Vixen/LSP, etc.
This really boils down to an engineering decision made based on what was available at the time. Since there were 4 sockets and all 4 were used for data there was no option but to have a temporary webpage. Now we get 8 for the same price so moving forward this will be a non-issue.
