Connecting uSD to D1 Mini - need pin connections
GPIO zero is the default GPIO used by the LoLin SD card. That is why I chose it. And yes, you are using the correct image. THat one is set up to work with an unmodified LoLin SD interface.
Sorry to be a pest, but 0 entry for SD Chip Select doesn't allow me to save. Plus it changes the entry field outline to RED and adds a bang (exclamation point circled in red)
I'm reading this 0 is an invalid entry - 1 to 40 seem to be the only valid entries.
I think I have solved the missing files in fpp connect in the latest version on my fork. I had to trade some speed (ok a lot of speed) for reliability.
You can flash your device and try it via the web flash tool or by downloading it from my release archive.
Here is a url for the online flash tool. Use the dist dated May 16 from the list of dists.
https://espixelstickwebflasher.from-ct.com:5000/
I have also added support for an FTP server running on the ESP. It allows you to connect to the ESP using FileZilla. FTP transfers are almost 2x faster than HTTP transfers. I have NOT tested with xLights.
Back
Top
