XmasLightGuy
Member
So I'm looking at _maybe_ doing some upgrades to my lights/display. really don't know for sure what if anything I'll do, there's various things I've considered...
Seeing some of the new stuff like RGB LED strings for the 1st time this year (and even getting a good up-close look at it thanks to a kind member on PC), all I can say is "that is awesome". but I think the cost is a deal-breaker for me...anyway I diegress there (as that would be a different topic...) LOL
My current thing is very simple - 24 channels with 3 parallel ports. One thing I've considered is simply adding more channels (and keep cost/work down) which is where something like 'Grinch' came to mind.
Looking around here some, it looks like it is 64 channels? (no dimming unless you do some sorta addon...and then it doesn't run off the parallel port anymore?? (which would exclude it as an option for me)) 64c would be more than enough for me (I'd probably use half of that to start)
It looks like with the schematic/parts-list I could fairly easily put one of those together. Are the SSR's for this the same thing like you'd use for a basic parallel controller (opto-isolator, a couple resistors & a Triac)? .. I might even be able to use my old 'boxes' if thats the case
One of my big questions is how does it work (this is a bit more technical)? Does it still use _only_ the 8 data out lines of a parallel port, or something more? Assuming just the 8, how do you turn on/off the channels - by this I mean what data are you sending to the port? (like with a simple 8-channel parallel control all I do is read a binary number, for simplicity say '00000000' for all off or'11111111' for all on, then convert that to hex and output it. with a grinch how does it work? are you sending multiple pulses for a single on/off command?)
Hopefully that all made sense...
