Pops-O-Matic ESP Programmer
Voltage Regulator
ESP Flashing Circuit
Pops-O-Matic Overview
1. 5mm Terminal Block
2. 3.5mm Terminal Block
3. Micro USB
4. Mini USB
5. Barrel Terminal Jack
Order a boards
- Input Connectors - As noted earlier, you have choices for the power input connector. You can populate the board with all the connectors at the same time. The exception to this is that the 3.5mm and 5mm terminal blocks share the same space on the board.
- S3 - Power Switch. SPDT ON-OFF-ON This part is optional. You can short the middle and left holes together to set the board to permanently ON. This SPDT switch has 5mm pin spacing. Most any style will do, both slide and toggle for example.
- D1 - Diode, specifically 1N5819
- C1 - MLCC, ceramic Capacitor. 50v, 0.1uF, 2.54mm or 5mm lead spacing.
- C2 - Electrolytic Capacitor. 10V, 220uF, 2mm lead spacing, 6mm max diameter.
- C3 - MLCC, ceramic Capacitor. 50v, 0.33uF, 2.54mm or 5mm lead spacing.
- C4 - Electrolytic Capacitor. 25V, 1000uF, 5mm lead spacing, 13mm max diameter.
- C5 - MLCC, ceramic Capacitor. 50v, 0.1uF, 2.54mm or 5mm lead spacing.
- C6 - Electrolytic Capacitor. 25V, 10uF, 2mm lead spacing, 6mm max diameter.
- POWER - LED, 5mm, any color.
- R1 - 1/4W carbon or metal film resistor. 10K ohm.
- R2 - 1/4W carbon or metal film resistor. 10K ohm.
- R3 - 1/4W carbon or metal film resistor. 10K ohm.
- R4 - 1/4W carbon or metal film resistor. 560 ohm.
- S1 - Tactile Switch. 6x6mm through hole.
- S2 - Tactile Switch. 6x6mm through hole.
- ESP01 - 2x4 femaie pin header. 2.54mm spacing.
- ESP01 - ESP-01 module.
- USB to TTL - A 6 pin header. Either vertical or 90 degree mounting. Male or Female to match the pins on your USB-to-TTL Converter.
- USB to TTL converter - This is not actually part of the Pops-O-Matic board, but you will need one if you don't already have one.
You can also order one off of TAYDA and is in the example BOM from noted below.
Errata
There is an unwanted trace on the back of the board that connects the right most pin of part C5 to the ground backplane that covers the bottom of the board.
