Troubleshooting Guide The Renard SS8
- This page is intended to help identify/isolate some of the common problems individuals encounter when building/operating the Renard SS8 controller board.
Basic Troubleshooting Info
Verify Setup
- Verify that the Renard SS8 is assembled correctly as compared to the Renard SS8 Controller Assembly Instructions wiki.
- Verify that you have power/control cables connected correctly as compared to the Renard SS8 Controller wiki.
- Verify that you have the Vixen plug-in settings correct as compared to the Renard SS8 Controller wiki.
Most Common Problems
- Bad data cable coming from the computer. Many individuals assume that all serial cables are identical, but that is far from the truth. Just because a cable has the correct DE9 connectors on each end doesn’t mean that the wires inside are going to the correct pins for Renard operation. It is always best to physically check the pin continuity to verify that the cable will work for Renard operation. Make sure that your interconnect cable is wired according to the Renard SS8 Controller wiki.
- Incorrect Vixen Settings. It cannot be emphasized enough, the Renard boards will not work correctly if Vixen is not setup correctly. Verify that you have the Vixen plug-in settings correct as compared to the Renard SS8 Controller wiki.
Troubleshooting the Renard SS8 Controller
Troubleshooting Flow
Troubleshooting Steps
- Verify that you have the power/control cables connected correctly as compared to the Renard SS8 Controller wiki.
- For the following steps, the PIC U6 needs to be programmed with the Renard Operational Firmware.
- Turn ON AC power
- PWR LED should be lit
- Run a Vixen sequence
Symptom(s):
- PWR LED not lit
- IC Chips hot to the touch
Possible Problem(s):
- No input voltage present
- Transformer bad
- Voltage Regulator bad
- LED installed backwards
- Blown fuse
- Remove power from Renard SS8
- Disconnect all cables.
- If installed, remove all 12 IC chips from their sockets (U2, U4 thru U6, and M1 thru M8).
- If not installed already, install an appropriate rated fuse in the fuse holder. Use the smallest value fuse that you have available for this portion of testing.
- Turn ON AC power.
- Did the fuse blow?
- If it did, go to step 16
- If incorrect, go to step 12
- Did the PWR LED light?
- If it did, go to step 20
- Measure DC voltage on right side of R6.
- Measure DC voltage on left side of R6.
- Measure DC voltage at cathode of D3 & D4.
- Measure AC voltage between left side of F1 and any N terminal.
- Measure AC voltage between right side of F1 and any N terminal.
- Turn OFF AC power
- Remove F1
- Turn ON AC power
- Recheck AC voltage between right side of F1 and any N terminal.
- If the voltage is now correct but was low or missing in step 15 or blew the fuse at initial turn-on, possible problems could be:
- Bad/shorted triac
- Turn OFF AC power
- Install one of the IC chips (U2, U4 thru U6, and M1 thru M8) into its respective socket.
- Turn ON AC power
- If it did, then repeat steps 21 thru 24 until all IC chips are installed.
Symptom(s):
- HB and ZC LED do not flash
- FE and/or OE LEDs light
- Oscillator bad
- Zero Cross signal bad
- Vixen settings incorrect
- PIC bad
- Turn OFF AC power
- Remove PIC chip U6
- Turn ON AC power
- Replace U2
- Check the values of R1 & R2
REMINDER:
The Renard SS8 Controller Board wiki page.
NOTE:
- SD LED will be ON whenever Vixen sends data to the Renard SS8. The FE and OE LEDs should remain OFF.
- If this is correct, then your Renard SS8 has passed the diagnostics test.
- Make sure that your interconnect cable is built according to the Renard SS8 Controller wiki.
- Replace U5
- Turn OFF AC power
- Turn ON AC power
- HB LED should light
- ZC LED should light
- SD LED should light
- FE LED should light
- OE LED should light
- b. Remove shunt from JP3
- d. Install shunt on JP3
- If incorrect, replace RN1
Symptom(s):
- Bad triac
- Bad opto
- Bad/missed solder joints
- Turn OFF AC power
- Are any of the triac gate resistors (R18-R25) burnt/blown/damaged?
- Turn ON AC power
- Test lights should be OFF
- If the test lights are ON, go to step 19
- Turn OFF AC power
- Install PIC chip U6
- Turn OFF AC power
- Turn OFF AC power
- Turn ON AC power
SAFETY NOTICE:
- Bad triac
- It should be 5 VDC
- Turn OFF AC power
- Turn ON AC power
- Is the test light still ON?
