Pops-O-Matic ESP Programmer
Revision as of 19:58, 14 December 2019 by Ukewarrior (talk | contribs) (→‎Errata)
Version V2
What is the Pops-O-Matic ESP Programmer ?
Voltage Regulator
ESP Flashing Circuit
Only Ground, Transmit, and Receive are connected from the external serial-to-TTL programmer to the Pops-O-Matic. (with the assumption you hook it up properly)
1. To protect the ESP-01 module from voltages over 3.3V. (Many TTL programmers are normally run at 5V)
Pops-O-Matic Overview
The board is designed to use any of the following for a power input connection types:
1. 5mm Terminal Block
2. 3.5mm Terminal Block
3. Micro USB
4. Mini USB
5. Barrel Terminal Jack
NOTE:
Input power should be at least 400ma.
Order a board
USE the Pops-O-Matic board at Your Own Risk !
The Pops-O-Matic board has NO warranty expressed or implied
You can also order one off of TAYDA as noted.
This board is pretty simple. Just follow typical assembly practices.
Solder from lowest to the board to tallest components last.
Hopefully, you can find some of the parts in your electronics junk drawer stash.
The only reason for five possible power inputs is to match up with whatever is easiest for you use from a power input source.
For example, the usb connections exist to support your typical cell phone charger or any other USB power source. (which is always 5V).
Or you may have an old power brick that has a round terminal barrel connector.
The voltage values of the referenced capacitors can be changed. You can always use a higher voltage capacitor in place of the noted voltage.
Additionally, you may be able to use a lower voltage than what is noted.
i.e. C3 and C4 are on the power input side of the voltage regulator.
If you know FOR SURE that you will never use a voltage over 5V for an input, then these capacitors can be any value above 7.5V and will be just fine. But, if you forget and apply 12V, the caps will let out their magic smoke.
Likewise, capacitors C1, C5 and C6 are after the voltage regulator and will never see a voltage above 3.3V. Therefore, any voltage rating above 5V should be safe.
All this to say is that you can often find a lot of the parts you need for a low voltage board like this in your stash or salvage from other boards.
Errata
small
small
This error has been fixed with the ver 1.1 board. (This version number is noted on the back of the board)
This may cause a problem if your C5 capacitor has 5mm spaced leads. In this case, you would either bend the leads to fit the more narrow spacing,
or you can insert the left most pin through the hole and then bend if over to connect to the middle hole.
In other words, part C5 must have pins touching the middle and right holes. Again, all references are from the top view of the board.
Pictures of built Pops-O-Matic boards
Tyson Howard's build:
Pops original build:
