Vastelec FM02
FM-02
click on the picture for a larger version
Vendor's Website
Data Sheet
Pictures of FM02's in enclosures
Each FM02 installation is unique !
A gallery of pictures and 'how to build notes' showing various FM02 installations is available.
Do you have a HUM ?
Some Beads split in half, some don't !
A Split Ferrite bead
A multi wrap Ferrite bead
There are some good pictures in the wiki-pedia-: http://en.wikipedia.org/wiki/Ferrite_bead
Audio
3.5mm stereo plug
Schematic and PCB layout
schematic
schematic
Detailed Board Dimensions
board dims
board dims
board dims 2
board dims 2
Antenna
smatobnc
smatobnc
You will need to buy or make an antenna. There are MANY different designs for antennas. A large number of DIYers have made a type of antenna known as a dipole. This is an easy to make antenna that will serve almost anyone's needs. Here is a link to a pdf with instructions to make your own: How to Make a Dipole Antenna
More recently, DIYC member Jhinkle published a paper for an antenna design that is easier to build with very good transmission characteristics.
Here is the link to a posting on the subject. DIYC discussion thread
You can go directly to the excellent design and build paper at this link: pdf paper for a ground plane antenna
What Frequency to Use
NOTE: There are seasonal radio stations. A open frequency in June may be used in December. You should plan accordingly.
http://www.radio-locator.com/
Where can I get one of these wonderful FM transmitters ?
RDS hookup information
fm02rds
fm02rds
fm02rds
fm02rds
Additional Modifications
PART15:
fm02block
fm02block
