What is the TIR Flood?
Manufacturer's Description
How does the TIR Flood work?
Dimensions of the TIR Flood
TIR Flood Components
Connectors
Housing
LED Assembly
Control Module
There is a control module that drives the LEDs and responds to the DMX commands provided to it thru the DMX interface. The Control Module is mounted inside a waterproof housing and is attached to the rear heatsink with a generous amount of heatsink compound. Inside of the Control Module there are some HEXFETs that appear to be driving the LEDs (IRL510S). There's a LM2676 5V regulator nearby some of these.
Ethernet Module
Power Supply
The power supply is a 100-240 VAC input and 24.5VDC 3.3A output. The power supply is sealed in a waterproof enclosure and the wires come through the enclosure via waterproof sealing glands.
The power supply has an input power cord on one end and has a red and black wire on the other end that connects to the control housing.
Mounting Bracket
Disassembling the TIR Flood
Main Body Separation
- Remove the 3 screws near the rounded back edge on both side panels near the bracket attachment.
- Loosen the Waterproof nuts on the wires entering on both sides of the module to allow the wire to slide through it.
- Remove the four screws that hold the black plastic housing to the base plate.
- Gently pry the black plastic housing from the base plate, it is held in place by a gasket.
- To completely remove the unit from the light housing, remove the screws holding the module base plate to the lamp housing. Wear gloves, there is a lot of thermal heat sink compound behind the base plate.
TIR Flood Power Requirements
AC Power Cable
Conductor | Wire Color |
Line | Brown |
Neutral | Blue |
Ground | Green/Yellow |
Controlling the TIR Flood
DMX Wire / XLR Connector
Signal | Wire Color | XLR Pin |
DMX IN Shield | Red Foil | 1 |
DMX IN + | Red Wire in Red Foil | 3 |
DMX IN - | Black Wire in Red Foil | 2 |
DMX OUT Shield | Green Foil | NC |
DMX OUT + | Red Wire in Green Foil | NC |
DMX OUT - | Black Wire in Green Foil | NC |
Internal Wiring Color Codes
LED Connection | Wire Color |
Common (+) | Red/Green |
RED | Red/Black |
GREEN | White/Black |
BLUE | Green/Black |
Upper section
Common (+) | Black/Red |
RED | White |
GREEN | Black |
BLUE | Red |
Lower section
Common (+) | Orange/Red |
RED | Orange |
GREEN | Green |
BLUE | Blue |
Thermistor
LED Connector
Pin Number | Wire Color |
1 | White |
2 | Green |
3 | Blue |
4 | Red/Black |
5 | Orange/Black |
6 | Black/White |
7 | Green/White |
8 | Black/Red |
9 | Orange/Red |
10 | Red/Green |
11 | Black/Red/White |
12 | Red/Black/White |
13 | Black |
14 | Red |
15 | Orange |
16 | White/Black |
17 | Green/Black |
18 | Blue/Black |
19 | Red/White |
20 | Blue/White |
21 | White/Red |
22 | Blue/Red |
23 | Thermistor \ |
24 | Thermistor / attached to Netburner module |
Replacement Power Supplies
Replacement Control Modules
DMX Address Translation Board
Documentation
Quick Start Product Guide
Wiring Schematic
Destiny CG Datasheet
ControlFx Software
TIR Flood Discussion Threads
Initial Thread
Test Pattern
Outdoor Test
Another outdoor test
Other Photos
