Different Styles of Pixels
Pixel Properties
Form Factor
- Strips (Usually 5M length)
- Modules
LEDs per meter
- Strips
- 30 LED/m
- 60 LED/m
- Strings
Power Supply Voltage
- 5VDC
- 12VDC
- 24VDC
LED Type
Waterproofing
Wire Size
- 20 Guage wire
- LPD1101
- UCS6909
- UCS6912
- LPD8806
- LPD8809
- SM16715
- SM16716
- P9813 - 4 wire
- P9816 - 4 wire
- TLS3002
- CYT3001
- CYT3005 - 3 wire
- MY9941 (Native DMX)
- MY9942 (Native DMX)
- MY9943 (Native DMX)
DIYLEDEXPRESS.COM
Form Factor | IC | Length | Voltage | LEDs per Meter | ICs per meter | Link | Image |
String | WS2811 | 50 pixels | 5vdc | 10 | 10 | link | |
String | WS2801 | 50 pixels | 5vdc | 10 | 10 | link | |
String (Square) | WS2811 | 50 pixels | 12vdc | 10 | 10 | link | |
Module | WS2811 | 20 pixels | 12vdc | 10 | 10 | link | |
Strip | TM1809 | 150 Pixels (5m) | 12vdc | 30 | 10 | link | |
Strip | WS2811 | 50 pixels (5m) | 12vdc | 30 | 10 | link | |
Strip | WS2811 | 100 pixels (5m) | 12vdc | 60 | 20 | link |
Ray Wu
Example | Example | Example | Example | Example | Example | Example | Example |
Stellascapes
String (Stella-green) | WS2801 | 85 pixels | 5vdc | 10 | 10 | link | Example |
String (Stella-black) | WS2801 | 42 or 85 pixels | 5vdc | 10 | 10 | link | Example |
