Different Styles of Pixels
There are many options and configurations and each has it's advantages and disadvantages depending on the application. Some of the most popular Pixels are ones driven by the WS2811 IC and use 12VDC power and use some form of cast epoxy waterproofing. They are a good balance of new technology and reliable designs.
Pixel Properties
Form Factor
- Strings Can be any purchased in any custom length, but more then 50 pixels will require Power Injection. It important to remember that Pixel strings should never be strung using their wire to support them like you would with regular light stings. This will damage the Pixels and their waterproofing. Common methods to support Pixel strings include using cable ties or electric tape to attach them to PVC pipe, EMT electric conduit or Plastic Strapping. Strings are commonly used to make Megatrees, Minitrees and Leaping Arches.
- 12mm pixel - This is the most common Pixel type. It actually contains a 8mm LED inside the housing. The 12mm refers to the outer diameter of the package. These were orginally designed to mount inside of enclosures and are used for large advertising display screens.
- 12mm pixel (square) - These pixels can come with the wire coming either out of the back of the Pixel or the side of the Pixel. There has been some issues with the silicone injection molded units that have the wires coming out of the side not sealing and allowing water into the pixels.
- Pixels with Lens - There are a variety of Pixels available with Plastic Lens mounted on the RGB LED to make them look closer to a traditional C7 or C9 incandescent light. Common models include the Ge Color Effects (GECE), the Pixabulb by diyledexpress.com, the Cosmic Color Bulbs by Lightorama.com and the Technicolor Pixel by Ray Wu. Vendors like Ray Wu also sell Plastic lens that can be glued onto regular 12mm Pixel strings to achieve a similar look.
- Strips Are long flat flexible PCBs that have the RGB LEDs and the IC mounted directly on them and there is no wire between the Pixels other than the PCB. They generally come in 5M lengths. Depending on the Pixel IC used, from 1-3 RGB LEDs will light for each Pixel, so they can end up looking more like Dashes (- - - -) when there are 3 RGB LEDs per Pixel vs. Dots (.. . .) when there is 1 RGB LED per Pixel. Many strips can be cut shorter, but you must only cut a the marks on the strip identifying where they are cutable. You may have to solder wires to the PCB if you are doing Power Injection or cutting the strips. It is very helpful to use flux and a smaller soldering iron so you do not damage teh delicate pads on the flexible PCB. Strips are commonly used to make Pixel Matrix on Flat Surfaces or as outlines around doors and windows.
- Hollow Tube - This is the most common Pixel Strip. They are basically the uncoated Bare Board Pixel Strip pulled into a hollow Silicone Tube. You must use some form of [[Waterproofing Pixels|Waterproofing] like neutral cure GE Silicone II to seal the ends where the wires attach to the PCBs.
- Silicone Coating
- Epoxy Resin Coating
- Solid Tube - The bare PCBs are also available in hollow tubes that have been filled with various waterproofing compoounds.
- Solid Silicone
- Solid Epoxy Resin
- Modules
LEDs per meter
- Strips
- 30 LED/m
- 60 LED/m
- Strings
- 5VDC
- 12VDC
- 24VDC
LED Type
Waterproofing
Wire Size
- 20 Guage wire
- LPD1101
- UCS6909
- UCS6912
- LPD8809
- SM16715
- P9813 - 4 wire
- P9816 - 4 wire
- TLS3002
- CYT3001
- CYT3005 - 3 wire
- MY9942 (Native DMX)
- MY9943 (Native DMX)
DIYLEDEXPRESS
Light-O-Rama (LOR)
(USA Based)
Ray Wu
(China Based)
Retail Store (i.e. Lowes)
Seasonal Entertainment
Stellascapes
DIYLEDEXPRESS
HolidayCoro
| String | None | 50 nodes (5m) | 12vdc | 10 | 0 | link | $32.50 | $0.65 | ||
| Strip | None | 5m | 12vdc | 30 | 0 | link | $49.99 | $10.00/m | silicone tube and coating | |
| Module (rectangular) | None | 20 nodes | 12vdc | 10 | 0 | link | $25.80 | $1.29 | 3 LEDs | |
| Module (square) | None | 20 nodes | 12vdc | 10 | 0 | link | $27.80 | $1.39 | 3 LEDs |
Ray Wu
(China Based)
Ray Wu
(China Based)
