Download and Installation
Revision as of 00:16, 26 October 2013 by Jlowe (talk | contribs) (Folder Hierarchy)
Download HLS
  • Tip: One way to organize the downloaded versions is to create a folder named "HLS Versions" and save downloads there.
  • Unzip the HLS_Install_**.zip and four files will be created in a folder named the same as the zip file. These four files are:
DBGHELP.DLL
ftd2xx.dll
HLS.exe
ipworks8.dll
Folder Hierarchy
Note: Prior to version 16K, the HLS Program and Data all were contained within the HLS Application folder. Starting in version 16K, data can be set to any place you want. Your Documents folder, an external hard drive, etc. Follow the Moving HLS Data Directories page to separate data from application.
Wherever you decide to save HLS data, the following structure is suggested:
HLS
HLS\Backgrounds
HLS\Library
HLS\Music
When you create an HLS sequence, HLS will create a folder under your HLS folder with the sequence name.
HLS Installation
  • Now that you have the foundation of folders created, copy the four files from the HLS_Install_**.zip version into your "HLS" folder.
  • Now you are ready to run HLS.
  • Note: If you are using Windows 7 you need to change the properties of the HLS.exe file to run as Administrator.
  • Open HLS.exe and begin to sequence.
OS Specific Installation
Windows XP HLS Installation
Linux HLS Installation
OSX HLS Installation
Main Page Chapter 1: Getting HLS Upgrading HLS
