FM02 Gallery
Pictures of Various FM02 and other VAST product Installations . . . . . . Click on the pictures !
By OregonLights.
FM02
By OregonLights.
FM02
By Underdog.
FM02
By Underdog.
FM02
By CaptKirk.
FM02
Mounted in an Aluminum case -
By chelmuth.
FM02
By chelmuth.
FM02
By smartalec.
FM02
By RobDude30.
FM02
By RobDude30.
FM02
By rkhanso.
FM02
By rkhanso.
FM02
By klanger.
By AURBO99.
By AURBO99.
By imbluenote.
By kingofkya.
By dmcole.
1 Watt VAST unit
By rogelio.
FM02 with MicroRDS unit
By rfallatt
FM02
By rfallatt
FM02
By rfallatt
FM02
By SamJ435.
By SamJ435.
By pcoshatt
FM02
By pcoshatt
FM02
By hasoon
FM02 with Wall Wart Tamer
By hasoon
By jduawa
FM02
By jduawa
FM02
By Howards9
FM02
By Howards9
FM02
By idleup
FM02
CableGuard CG-1000 Demarcation Enclosure Customized for FM-02 transmitter and accessories with power switch assembly SLM2596 Buck Converter Step Down Power Regulator and Conditioner (3v to 40v) BH1415 Sound Quality Improvement Modification (modifies 19Khz pilot tone level to reduce hum and improve sound quality) Wall Wart Power Pack (I used one from an old dust buster, the SLM2596 will allow you to use any adapter 3v to 40v for your input power) -
By idleup
FM02
By nuelemma
FM02
A project box installation -
By nuelemma
FM02
By griffixdc
FM02
this is my fm02 in its enclosure i made 2 years ago..i used a dsl phone filter box ...its perfectly small -
By griffixdc
FM02
By CaptainMurdoch
FM02
Here are a few pics of my 10-minute, $0.50 from-a-garage-sale case. I believe it was originally a first aid kit from Johnson & Johnson. I used a few extra screws from my box-of-parts and cut the holes using a drill and saw. Could have been a bit neater if could have waited a few weeks until after I picked up a Sears 'dremel' at another garage sale. I still have a bit of room inside the case if I want to add something else or an internal regulated power supply. -
By CaptainMurdoch
FM02
By Modderhut
FM02
used an old ISDN2 NT1 casing, drilled a hole and hot glu-ed the antenna in. -
By Juicedss
FM02
I bought a new iPhone yesterday which inspired me to put together the FM02. -
By Juicedss
FM02
By sjswanner
FM02
This enclosure was created using a hobbyist 3D printer and a design done in solidworks. -
By sjswanner
FM02
By duramadmax
FM02
Fit a regulated power supply, RDS board and FM02. It includes a FTDI DB9-USB-F adapter. -
By duramadmax
FM02
By Uncle Al
FM02
This is a custom, laser cut, enclosure in acrylic. -
By Uncle Al
FM02
By mndless
FM02
This is a custom, laser cut, enclosure in masonite. These are the cutout pieces that are then glued together. -
By mndless
FM02
This is the finished enclosure. -
By corytcline
FM02
A plastic tub is sometimes all you need for an enclosure -
By corytcline
FM02
