ESPixel Stick & ESPixel Pops
Version V2
Version V2
Version V2
Version V2
Version V2
Version V2
What is a Pixel Stick?
Pixel Pops & Tiny
Therefore, if you use the TINY board, you must have some other mechanism in order to program the ESP-01 module.
small
small
Order your own boards
If ukewarrior is out of boards, you can order them in groups of 3 from OSHPark: Click here for the Ordering link at OSHPark to order your own boards
Fuse Holder
5A Fuse
Version V2
The BOM's are:
Mouser BOM is in Post #35
Arrow BOM is in Post #48
Digikey BOM is in Post #49
small
small
Wiring The ESPixel Pops
small
small
small
small
A Key Point Regarding Power
Programming the ESP-01 Module
The ESPixel Pops board can do this, (but not the Tiny)
Upload the firmware
Download the latest Firmware.
Install Java JRE.
