ESPixel Stick & ESPixel Pops
Revision as of 19:32, 22 March 2020 by Ukewarrior (talk | contribs) (BOM - Bill of Materials)
Version V2
Version V2
Version V2
Version V2
Version V2
Version V2
What is a Pixel Stick?
As a result, there is one common firmware thread that works on all of the ESP-01 based DIYC pixel sticks.
Pixel Pops & Pixel Pops Tiny
Pops-O-Matic Info
small
small
Order your own boards
These are available for a total of 34 cents from Tayda Electronics.
Fuse Holder
5A Fuse
Version V2
The BOM's are:
Mouser BOM is in Post #35
Arrow BOM is in Post #48
Digikey BOM is in Post #49
Build Guides
These can be found on his blog:
ESPixel Pops Build Guide and DMX enhancement
small
small
Wiring The ESPixel Pops
small
small
small
small
A Key Point Regarding Power
A 3D printed Mount for your Pixel Pops controller
A small Item that you can mount in a cable guard box or other waterproof enclosure
The .stl file is available for free on thingiverse at this link:
Thingiverse link for Pixel Pops mount
Programming the ESP-01 Module
As of 11/21/2019, the current release by Shelby that implements dimming control and other features.
Upload the firmware
Download the latest Firmware.
Install Java JRE.
William Napier crated these in a few hours as a novice solderer. All worked fine on the first try !
