What is the TIR Flood?
Manufacturer's Description
How does the TIR Flood work?
These are RGB flood lights that are controlled via DMX and possibly via an unidentified ethernet based protocol. There is a 5 pin XLR DMX connector that comes configured for DMX input only. Out of the box these units respond to DMX channels 1-3 when powered up and connected to a signal source. These units will fall back to a test sequence if the DMX signal is not applied. The test sequence is a series of color fades. The units also come with a ethernet cable attached and the control protocol has not been established for using it.
Dimensions of the TIR Flood
TIR Flood Components
Connectors
Housing
LED Assembly
Control Module
There is a control module that drives the LEDs and responds to the DMX commands provided to it thru the DMX interface. The Control Module is mounted inside a waterproof housing and is attached to the rear heatsink with a generous amount of heatsink compound. Inside of the Control Module there are some HEXFETs that appear to be driving the LEDs (IRL510S). There's a LM2676 5V regulator nearby some of these. The only large chip on the board is on the backside - has a LDT logo on it, with a LD71D1048C designation.
Ethernet Module
Power Supply
The power supply is a 100-240 VAC input and 24.5VDC 3.3A output. The power supply is sealed in a waterproof enclosure and the wires come through the enclosure via waterproof sealing glands. The power supply has an input power cord on one end and has a red and black wire on the other end that connects to the control housing.
Mounting Bracket
Disassembling the TIR Flood
Main Body Separation
  1. Remove the 3 screws near the rounded back edge on both side panels near the bracket attachment.
TIR Flood Power Requirements
AC Power Cable
ConductorWire Color
LineBrown
NeutralBlue
GroundGreen/Yellow/Black
Controlling the TIR Flood
DMX Wire / XLR Connector
SignalWire ColorXLR Pin
DMX IN ShieldRed Foil1
DMX IN +Red Wire in Red Foil3
DMX OUT ShieldGreen FoilNC
DMX OUT +Red Wire in Green FoilNC
Wiring Color Codes
LED ConnectionWire Color
Common (+)Red/Green
REDRed/Black
GREENWhite/Black
BLUEGreen/Black
Upper section
Common (+)Black/Red
REDWhite
GREENBlack
BLUERed
Lower section
Common (+)Orange/Red
REDOrange
GREENGreen
BLUEBlue
Thermistor
LED Connector
Pin NumberWire Color
1White
2Green
3Blue
4Red/Black
5Orange/Black
6Black/White
7Green/White
8Black/Red
9Orange/Red
10Red/Green
11Black/Red/White
12Red/Black/White
13Black
14Red
15Orange
16White/Black
17Green/Black
18Blue/Black
19Red/White
20Blue/White
21White/Red
22Blue/Red
23Thermistor \
Replacement Power Supplies
Replacement Control Modules
Non-OEM replacement for the Control Module options include a DCSSR driven by a controller such as the REN48LSD, Simple Renard 32 or the REN64.
DMX Address Translation Board
Documentation
Quick Start Product Guide
Wiring Schematic
Destiny CG Datasheet
TIR Flood Discussion Threads
Initial Thread
Test Pattern
Outdoor Test
Another outdoor test
Other Photos
