Different Styles of Pixels
Pixel Properties
Form Factor
- Strips (Usually 5M length)
- Modules
LEDs per meter
- Strips
- 30 LED/m
- 60 LED/m
- Strings
Power Supply Voltage
- 5VDC
- 12VDC
- 24VDC
LED Type
Waterproofing
Wire Size
- 20 Guage wire
- LPD1101
- UCS6909
- UCS6912
- LPD8806
- LPD8809
- SM16715
- SM16716
- P9813 - 4 wire
- P9816 - 4 wire
- TLS3002
- CYT3001
- CYT3005 - 3 wire
- MY9941 (Native DMX)
- MY9942 (Native DMX)
- MY9943 (Native DMX)
Retail Store (i.e. Lowes)
Form Factor | IC | Length | Voltage | LEDs per Meter | ICs per meter | Link | Image | Note |
String | GECE | 25,36,50 pixels (20,29,41ft) | 5vdc | 4 | 4 | link | G35 Cover, General Electric Color Effects |
DIYLEDEXPRESS
String | WS2801 | 50 pixels (6m) | 5vdc | 10 | 10 | link | IP68 | |
String | WS2811 | 50 pixels (6m) | 5vdc | 10 | 10 | link | IP68 | |
String (Square) | WS2811 | 50 pixels (6m) | 12vdc | 10 | 10 | link | IP68 | |
Module (Rectangular) | WS2811 | 20 pixels (2m) | 12vdc | 10 | 10 | link | ||
Strip | WS2811 | 50 pixels (5m) | 5vdc | 30 | 10 | link | Silicone Tube | |
Strip | WS2811 | 100 pixels (5m) | 5vdc | 60 | 20 | link | Silicone Tube | |
Strip | TM1809 | 150 Pixels (5m) | 12vdc | 30 | 10 | link | Silicone Tube |
Ray Wu
String | WS2801 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68 | |
String | WS2801 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68, with faceted C9 cover | |
String | WS2801 | 100 pixels (10m) | 12vdc | 10 | 10 | link | IP68 | |
String (square) | WS2801 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68 | |
String (square) | WS2801 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP66, side wire | |
String (square) | WS2801 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68, with faceted C9 cover | |
Strip | WS2801 | 160 pixels (5m) | 5vdc | 32 | 32 | link | IP65, silicone tube | |
Strip | WS2801 | 60 pixels (5m) | 12vdc | 36 | 12 | link | IP65, silicone tube | |
Module (square) | WS2801 | 20 pixels | 12vdc | 40 | 10 | link | ||
String | WS2811 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68 | |
String | WS2811 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP66, with 4 pin waterproof connectors | |
String (square) | WS2811 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68 | |
String (square) | WS2811 | 100 pixels (10m) | 12vdc | 10 | 10 | link | IP66, side wire | |
Strip | WS2811 | 150 pixels (5m) | 5vdc | 30 | 30 | link | Silicone tube | |
Strip | WS2811 | 240 pixels (4m) | 5vdc | 60 | 60 | link | Silicone tube | |
Module (rectangular) | WS2811 | 20 pixels | 12vdc | 30 | 10 | link | ||
TBD | TBD | TBD | TBD | TBD | TBD | TBD | ||
Stellascapes
String (Stella-green) | WS2801 | 85 pixels | 5vdc | 10 | 10 | link | ||
String (Stella-black) | WS2801 | 42 or 85 pixels | 5vdc | 10 | 10 | link |
DIYLEDEXPRESS
String | None | 50 nodes (5m) | 5vdc | 10 | 0 | link | IP68 | |
String | None | 50 nodes (5m) | 12vdc | 10 | 0 | link | IP68 | |
Strip | None | 5m | 12vdc | 30 | 0 | link | IP65, can be cut every 3 LEDs | |
Strip | None | 5m | 12vdc | 60 | 0 | link | IP65, can be cut every 3 LEDs | |
Module (rectangular) | None | 20 nodes | 12vdc | 30 | 0 | link | IP66 |
Ray Wu
TBD | TBD | TBD | TBD | TBD | TBD | [TBD link] | TBD |
