Different Styles of Pixels
Pixel Properties
Form Factor
- Strips (Usually 5M length)
- Modules
LEDs per meter
- Strips
- 30 LED/m
- 60 LED/m
- Strings
Power Supply Voltage
- 5VDC
- 12VDC
- 24VDC
LED Type
Waterproofing
Wire Size
- 20 Guage wire
- LPD1101
- UCS6909
- UCS6912
- LPD8809
- SM16715
- P9813 - 4 wire
- P9816 - 4 wire
- TLS3002
- CYT3001
- CYT3005 - 3 wire
- MY9942 (Native DMX)
- MY9943 (Native DMX)
DIYLEDEXPRESS
Form Factor | IC | Length | Voltage | LEDs per Meter | ICs per meter | Link | Image | Price | Price per Pixel | Note |
String | WS2801 | 50 pixels (6m) | 5vdc | 10 | 10 | link | $26.00 | $0.52 | IP68 | |
String | WS2811 | 50 pixels (6m) | 5vdc | 10 | 10 | link | $24.25 | $0.49 | IP68 | |
String (C9) | WS2811 | 50 pixels (*m) | 12vdc | 3-10 | 3-10 | link | $45.00 | $0.90 | IP68, C9 lens with 2x5050LEDs, available with 4",6",8",10",12" spacing | |
String (Square) | WS2811 | 50 pixels (6m) | 12vdc | 10 | 10 | link | $25.75 | $0.52 | IP68, back wire | |
Module (Rectangular) | WS2811 | 20 pixels (2m) | 12vdc | 10 | 10 | link | $16.75 | $0.84 | 3 LEDs | |
Strip | WS2811 | 50 pixels (5m) | 5vdc | 30 | 10 | link | $42.50 | $0.85 | silicone tube | |
Strip | WS2811 | 100 pixels (5m) | 5vdc | 60 | 20 | link | $65.00 | $0.65 | silicone tube | |
Strip | TM1809 | 150 Pixels (5m) | 12vdc | 30 | 10 | link | $60.00 | $0.40 | silicone tube |
Light-O-Rama (LOR)
(USA Based)
String | LPD6803 | 100 pixels (15.25m) | 5vdc | 6.5 | 6.5 | link | $239.95 | $2.40 | Cosmic Color Pixels (with controller and Power Supply) | |
Bulbs | LPD6803 | 100 pixels (15.25m) | 5vdc | 6.5 | 6.5 | link | $289.95 | $2.90 | Cosmic Color Bulbs (with controller and Power Supply) | |
Strip | LPD6803 | 50 pixels (5m) | 12vdc | 30 | 10 | link | $249.95 | $2.50 | Cosmic Color Ribbon (with controller and Power Supply) |
Ray Wu
(China Based)
String | WS2801 | 50 pixels (5m) | 5vdc | 10 | 10 | link | $19.00 | $0.38 | IP68 | |
String | WS2801 | 50 pixels (5m) | 5vdc | 10 | 10 | link | $25.00 | $0.50 | IP68, with faceted C9 cover | |
String | WS2801 | 100 pixels (10m) | 12vdc | 10 | 10 | link | $40.00 | $0.40 | IP68 | |
String (square) | WS2801 | 50 pixels (5m) | 5vdc | 10 | 10 | link | $19.00 | $0.38 | IP68, back wire | |
String (square) | WS2801 | 50 pixels (5m) | 5vdc | 10 | 10 | link | $19.00 | $0.38 | IP66, side wire | |
String (square) | WS2801 | 50 pixels (5m) | 5vdc | 10 | 10 | link | $27.50 | $0.55 | IP68, with faceted C9 cover | |
Strip | WS2801 | 160 pixels (5m) | 5vdc | 32 | 32 | link | $72.00 | $0.45 | IP65, silicone tube | |
Strip | WS2801 | 60 pixels (5m) | 12vdc | 36 | 12 | link | $66.32 | $1.10 | IP65, silicone tube | |
Module (square) | WS2801 | 20 pixels | 12vdc | 40 | 10 | link | $20.08 | $1.00 | epoxy coated | |
String | WS2811 | 50 pixels (5m) | 5vdc | 10 | 10 | link | $17.00 | $0.34 | IP68 | |
String | WS2811 | 50 pixels (5m) | 5vdc | 10 | 10 | link | $21.50 | $0.43 | IP66, with 4 pin waterproof connectors | |
String (square) | WS2811 | 50 pixels (5m) | 5vdc | 10 | 10 | link | $18.00 | $0.36 | IP68, back wire | |
String (square) | WS2811 | 100 pixels (10m) | 12vdc | 10 | 10 | link | $40.00 | $0.40 | IP66, side wire | |
Strip | WS2811 | 150 pixels (5m) | 5vdc | 30 | 30 | link | $38.00 | $0.25 | silicone tube | |
Module (rectangular) | WS2811 | 20 pixels | 12vdc | 30 | 10 | link | $18.00 | $0.90 | ||
Strip | WS2812 | 240 pixels (4m) | 5vdc | 60 | 60 | link | $48.00 | $0.20 | silicone tube, WS2811 with integrated 5050 LED | |
String | LPD6803 | 50 Pixels (5m) | 5vdc | 10 | 10 | link | $23.00 | $0.46 | IP68 | |
String (square) | LPD6803 | 50 Pixels (5m) | 5vdc | 10 | 10 | link | $23.16 | $0.46 | IP68, side wire | |
Strip | LPD6803 | 50 Pixels (5m) | 12vdc | 30 | 10 | link | $65.26 | $1.31 | IP68, similar to LOR CCR | |
Module (square) | LPD6803 | 20 pixels (2m) | 12vdc | 10 | 10 | link | $21.00 | $1.05 | 3 LEDs | |
Module (rectangular) | LPD6803 | 20 pixels (2m) | 12vdc | 10 | 10 | link | $20.50 | $1.03 | 3 LEDs | |
String | TLS3001 | 50 pixels (5m) | 5vdc | 10 | 10 | link | $22.50 | $0.45 | IP68 | |
String | TLS3001 | 50 pixels (5m) | 5vdc | 10 | 10 | link | $26.00 | $0.52 | IP68, with 4 pin waterproof connectors | |
String (square) | TLS3001 | 50 pixels (5m) | 5vdc | 10 | 10 | link | $23.00 | $0.46 | IP68, back wire | |
String | TM1804 | 50 pixels (5m) | 12vdc | 10 | 10 | link | $20.00 | $0.40 | IP68, DIYLA Smart Strings | |
String | TM1804 | 100 pixels (10m) | 12vdc | 10 | 10 | link | $40.00 | $0.40 | IP68, DIYLA Smart Strings | |
Module (square) | TM1804 | 20 pixels (2m) | 12vdc | 10 | 10 | link | $22.00 | $1.10 | silicone coating, 3 LEDs, DIYLA Smart Modules | |
Module (rectangular) | TM1804 | 20 pixels (2m) | 12vdc | 10 | 10 | link | $14.00 | $0.70 | silicone coating, 3 LEDs, DIYLA Smart Modules | |
Strip | TM1809 | 150 pixels (5m) | 12vdc | 30 | 10 | link | $52.00 | $0.35 | IP67, silicone tube | |
Strip | TM1809 | 150 pixels (5m) | 12vdc | 30 | 10 | link | $52.00 | $0.35 | IP65, silicone coating | |
Strip | TM1809 | 240 pixels (5m) | 12vdc | 48 | 16 | link | $67.00 | $0.28 | IP68, silicone tube |
Retail Store (i.e. Lowes)
String | GECE | 25,36,50 pixels (20,29,41ft) | 5vdc | 4 | 4 | link | ~$2 | G35 Cover, General Electric Color Effects (with controller and Power Supply) |
Seasonal Entertainment
String | WS2801 | 42 pixels (4.2m) | 12vdc | 10 | 10 | link | $32.00 | $0.76 | IP68, Rainbow Mini Pixels | |
String (C7) | WS2801 | 42 pixels (8.4m) | 12vdc | 5 | 5 | link | $43.00 | $1.02 | IP68, Rainbow C7 Pixels | |
String (C9) | WS2801 | 42 pixels (8.4m) | 12vdc | 5 | 5 | link | $45.00 | $1.07 | IP68, Rainbow C9 Pixels | |
Strip | WS2801 | 42 pixels (4.2m) | 12vdc | 30 | 10 | link | $73.99 | $1.76 | IP68, Silicone filled, Rainbow Ribbon | |
Matrix | WS2801 | 42 pixels (0.15x0.18m) | 12vdc | xx | xx | link | $35.00 | $0.83 | Not Waterproof, Rainbow Matrix |
Stellascapes
String (Stella-green) | SS-1 | 85 pixels | 5vdc | 10 | 10 | link | $168 | $1.98 | bullet or flat packages | |
String (Stella-black) | SS-1 | 85 pixels | 5vdc | 10 | 10 | link | $240 | $2.82 | bullet or flat packages | |
Strip (Stella-black) | SS-1 | 85 pixels | 5vdc | link | 45 or 90mm pitch |
DIYLEDEXPRESS
Form Factor | IC | Length | Voltage | LEDs per Meter | ICs per meter | Link | Image | Price | Price per Node | Note |
String | None | 50 nodes (5m) | 5vdc | 10 | 0 | link | $18.75 | $0.38 | IP68 | |
String | None | 50 nodes (5m) | 12vdc | 10 | 0 | link | $19.75 | $0.40 | IP68 | |
Strip | None | 5m | 12vdc | 30 | 0 | link | $19.25 | $3.85/m | IP65, can be cut every 3 LEDs | |
Strip | None | 5m | 12vdc | 60 | 0 | link | $26.35 | $5.25/m | IP65, can be cut every 3 LEDs | |
Module (rectangular) | None | 20 nodes | 12vdc | 30 | 0 | link | $13.50 | $0.68 | IP66 |
HolidayCoro
String | None | 50 nodes (5m) | 12vdc | 10 | 0 | link | $32.50 | $0.65 | ||
Strip | None | 5m | 12vdc | 30 | 0 | link | $49.99 | $10.00/m | silicone tube and coating | |
Module (rectangular) | None | 20 nodes | 12vdc | 10 | 0 | link | $25.80 | $1.29 | 3 LEDs | |
Module (square) | None | 20 nodes | 12vdc | 10 | 0 | link | $27.80 | $1.39 | 3 LEDs |
Ray Wu
(China Based)
String | None | 50 nodes (5m) | 5vdc | 10 | 0 | link | $12.00 | $0.24 | IP68 | |
String | None | 100 nodes (10m) | 12vdc | 10 | 0 | link | $24.00 | $0.24 | IP68 | |
Strip | None | 5m | 12vdc | 30 | 0 | link | $16.00 | $3.20/m | silicone tube | |
Strip | None | 5m | 12vdc | 30 | 0 | link | $16.00 | $3.20/m | IP68,silicone coating | |
Strip | None | 5m | 12vdc | 30 | 0 | link | $24.00 | $4.80/m | IP68,silicone tube and coating | |
Strip | None | 5m | 12vdc | 30 | 0 | link | $20.53 | $4.11/m | epoxy coating | |
Strip | None | 5m | 12vdc | 60 | 0 | link | $22.00 | $4.40/m | silicone tube | |
Strip | None | 5m | 12vdc | 60 | 0 | link | $32.00 | $6.40/m | IP68,silicone tube and coating | |
Strip | None | 5m | 12vdc | 60 | 0 | link | $41.05 | $8.21/m | epoxy coating | |
Module (rectangular) | None | 20 nodes | 12vdc | 10 | 0 | link | $8.00 | $0.40 | IP65, 2 LEDs | |
Module (rectangular) | None | 20 nodes | 12vdc | 10 | 0 | link | $9.00 | $0.45 | IP66, 3 LEDs | |
Module (square) | None | 20 nodes | 12vdc | 10 | 0 | link | $14.74 | $0.74 | IP68, 3 LEDs | |
Module (square) | None | 20 nodes | 12vdc | 10 | 0 | link | $9.50 | $0.48 | IP67, 4 LEDs |
String | None | 50 nodes (5m) | 12vdc | 10 | 0 | link | $19.00 | $0.38 | IP68 | |
String (square) | None | 50 nodes (10m) | 12vdc | 5 | 0 | link | $38.99 | $0.78 | IP68, RGB C7 lens | |
String (square) | None | 50 nodes (10m) | 12vdc | 5 | 0 | link | $39.99 | $0.80 | IP68, RGB C9 lens | |
Strip | None | 5m | 12vdc | 30 | 0 | link | $38.50 | $7.70/m | IP68, Silicone filled |
