RGB Channels
This page is in process of being revised.
Introduction to RGB
Adding RGB Channels
Revision needed.
1A also contains a three channel - Red, Green, Blue - conversion into a single RGB channel. This should help reduce channel count from a converted Vixen file.
The way to do the RGB conversion follows: Add your RGB channels to your sequence. Create a group that contains a few of your new RGB channels and their associated single channels.
Under the Menu "Manage Channels" - select "Convert Three Channels to RGB". Note the warning about overlapping channels - you can manually clean those up later. Perform the conversion.
When you are happy with the conversion - go into "Manage Raw Channels" and DELETE the three single channels - NOTE - they will not be removed until you close HLS down. Close HLS - then restart HLS. Conversion is now complete and old channels are gone leaving only single RGB for you to sequence with.
Channel Reduction
RGB can also be used to program non-RGB lights to reduce the number of channels by 2/3. For example, imagine a Mega tree with 16 strings red, white and blue lights (48 strings total). Each RGB channel could represent 3 outputs, red, white, and blue. When programming, if red is chosen for the effect the red lights would be on. When green is chosen for the effect the white string would be on, when Blue is chosen blue would be on. If white is chosen for the effect color, all three would be on.
Advanced Channel Management | Chapter 3: Channel Management | Configuring Display Groups |
