Download and Installation
Revision as of 20:21, 31 January 2013 by Jlowe (talk | contribs)
Download HLS
  • Tip: One way to organize the downloaded versions is to create a folder named "HLS Versions" and save downloads there.
  • Unzip the HLS_Install_**.zip and four files will be created in a folder named the same as the zip file. These four files are:
DBGHELP.DLL
ftd2xx.dll
HLS.exe
ipworks8.dll
Folder Hierarchy
  • At a minimum, it is suggested to create a folder layout of five folders as follows (folders needing to be created are in bold type):
HLS
HLS\Backgrounds
HLS\Library
HLS\Music
HLS\Sequences
  • Each sequence you create will create additional files, therefore, it is an excellent practice to make a sub-folder under the "HLS\Sequences" folder for each new sequence you create. For example:
HLS\Sequences\My first sequence
HLS Installation
  • Now that you have the foundation of folders created, copy the four files from the HLS_Install_**.zip version into your "HLS" folder.
  • Now you are ready to run HLS.
  • Note: If you are using Windows 7 you need to change the properties of the HLS.exe file to run as Administrator.
  • Open HLS.exe and begin to sequence.
OS Specific Installation
Windows XP HLS Installation
Linux HLS Installation
OSX HLS Installation
Main Page Chapter 1: Getting HLS Upgrading HLS
