Adding and Using Beat Tracks
Revision as of 20:38, 31 January 2013 by Jlowe (talk | contribs)
This is based on version 11V.
HLS supports creating beat tracks in a couple of ways. One way is to manually press a button or click a mouse while a song is playing to set the beat. Another way would be to apply a filter to the audio and then manually "turn on" the beat track at points identified through the filter.
Add Beat Track Channels
Figure 5-5
First, channels must be added so you can use them as beat tracks.
  • Open the Channel Manager (Manage Channels -> Manage Raw Channels)
  • Since we are going to look at three different ways to create a beat track, go ahead and Add 3 channels named "Beat".
  • Keep the Universe as 0 since these channels will not be associated with real output.
  • Use the color Selector to set colors for your beat tracks (see Figure 5-5).
  • When done, select Save Changes.
Setting Display Group for Beat Track
Figure 5-6
  • Next, assign all of the beat tracks into their own Display Group.
  • Create a Display Group named "Beat" and add all three channels (See Figure 5-6).
  • Set the "Beat" display group as the group to work with.
Beat Track From Clicks
Creating a Beat Track from Clicks is one of the easiest ways to create a Beat Track. Clicks must be quick and not everything will line up perfectly, but it can give reasonably good results.
Figure 5-7
  • Activate the Beat Track by clicking Manage Channels -> Select a Beat Track Channel.
  • Select the Beat Track you want to use and click OK (See Figure 5-7).
Figure 5-8
  • Check the box Beat Track Active to let HLS know that you are planning to record clicks for a beat track (see Figure 5-8).
  • Press the Play / Pause button to play the song.
  • Press the CTRL key or the Left Mouse' button at each beat in the song.
Figure 5-9
  • When the song is complete, there will be two grid cells filled in at every click received. Your beat track has been created. (See Figure 5-9)
Beat Track from Filters
Section needs to be completed.
How to use the filters/link to audio file page. Filling in squares for beat track.
Cleaning up a Beat Track
  • To move a mark left or right, Click on the FIRST grid-square, release the mouse button, and then move it using the mouse and dragging.
  • When the timing mark is placed where you want it, click on it again (or press escape) to exit selection mode.
