Color Stick
The color stick is an 8-pixel (24 DMX channels) LED display. Each pixel is made of two RGB 5050-sized LEDs; the LEDs can either be loaded on both sides or all on one side.
From Mouser:
581-06035A220J|2
81-GCM188R71H104KA7J|9
810-C1608X7R1A334K|2
810-C3225X7R1E106M|1
720-LYQ971H1K136|1
649-67996-402HLF|1
538-70287-1001|1
22-28-1040|1
22-15-2046|1
301-1.0K-RC|4
302-4.75K-RC|1
595-TLC5916IDG4|3
701-SP485RCN-L|1
556-ATMEGA48P-20AU|1
815-ABMM-20B2-T|2
821-TS78L05CT|1
In addition, you need 16 5050-sized RGB LEDs; the ones from the group buy are ideal. Mouser 593-VAOS-5050RGBW1 would also work, but the channel mapping of red and blue would be reversed.
Schematic (PDF)
PCB
Front-side copper (PDF)
Back-side copper (PDF)
Front-side silkscreen (PDF)
Back-side silkscreen (PDF)
Assembly manual
Assembly manual (PDF)
RPM has developed updated firmware for the color stick. Choose the appropriate hex file for the version of the processor on your board (it will work with the ATMega48, 88, 168, or 328) Firmware
Source code
color_stick_code.zip
