Electronics Hardware
Links
SSR Direct Attach
Kit74
Hill320
Olsen 595/Grinch
- Documentation: Olsen 595
Firegod
- Documentation: Firegod
The overall orchestra of the system looks like this:
Renard
- Documentation: Renard
Lynx
- Controlled through: DMX
Ledtriks
- Documentation: LedTriks Controller Assembly Instructions
JEC Pixel Displays
rgbLED
TBA
Lynx (DMX dimmer)
Inside the Lynx
