Electronics Hardware
Links
SSR Direct Attach
Kit74
Hill320
Olsen 595/Grinch
- Documentation: Olsen 595
Firegod
- Documentation: Firegod
Renard
- Documentation: Renard
Lynx
- Controlled through: DMX
Ledtriks
Tricks-c
- Controlled through: Serial port or standalone
- Documentation: [TBA]
This is a an add on controller/process for the Ledtricks. One of the problems with the original LEDTRIKS design was the load placed on the PC to chunk the data out the parallel port. The TRICKS-C uses a ATMEL process to take a LEDSTRIKS file and send it out to the LEDTRIKS Controller, via the serial prot.
JEC Pixel Displays
rgbLED
TBA
Renard SS 8
Renard SS 16
Renard SS 24
Digital Input/Output Cards
