Carousel Build
Some pictures of the wording for the base / floor.
Pictures of the slip ring installed
Looks like my trusty wiper motor isn't strong enough to lift the caracters up and down. The wieght of the plywood, especially all three, are just too heavy.
Wait a minute. :hmm: Normally only two would be in exact sync with each other, the next two would be 1/3 behind and the next two would be 2/3 behind. If all of the characters weigh the same, everything should be in balanced. So if you added weight to match the heaviest one the motor should only have friction as the load.
Looks great, I built mine last year, it's about 8' across, kept running into motor issues, what kind of motor did You run it on that will stay running over the long hall?
Wiper motor. I use them for almost all of my projects. Cheap, great tourque even at low voltage and a work horse.
I had not thought of that motor, I used a garage door opener, not for running very long, tried a dryer motor, not enough to turn it, will find a wiper motor, any brand GM, Ford, Chrysler work any better.
Back
Top
