I will start this post off with: AWESOME!!! This has made creating a preview so much easier!!! Thank you.
Now the bug.... when using Elf Preview in the profile for my sequences, it works fine when running a single sequence. When I have Elf Preview enabled in my profile when trying to run a program of sequences, it crashes Vixen 2.1.1.0. I have created a program of my sequences, chose to use 'Use each sequence's plugin setup" and when I try to run the program from the dialog, it starts off with a pop-up "Object reference not set to an instance of an object". Click Ok, then the stop button and get an unhandled exception error "Object reference not set to an instance of an object." and the following trace:
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at ElfPreview.PreviewDialog.cmdStop_Click(Object sender, EventArgs e) in c:\Users\roba\Documents\Visual Studio 2012\Projects\Editable Adjustable Preview\ElfPreview Vixen 2.1x\PreviewDialog.cs:line 101
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Then close the window, choose to save changes and then I get another unhandled exception "Collection was modified; enumeration operation may not execute with the following trace:
System.InvalidOperationException: Collection was modified; enumeration operation may not execute.
at System.Collections.ArrayList.ArrayListEnumeratorSimple.MoveNext()
at System.Windows.Forms.Application.ExitInternal()
at System.Windows.Forms.Application.ThreadContext.OnThreadException(Exception t)
at System.Windows.Forms.Control.WndProcException(Exception e)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
at Vixen.Form1.manageProgramsToolStripMenuItem_Click(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
These errors happen no matter what selection I make for the program.
I have also noticed the slow load when going into the plugin setup in the profile manager. I have 230 channels with this profile.
