MartinMueller2003
Supporting Member
Mine comes tomorrow. My mailbox is all dressed up and ready to receive it
Ugh! I literally just finished flashing 4 units and disconnected the FTDI connector and patch wires.
Received mine, but I have a question on the build: how are the 6mm buttons oriented on the board? I assume the square solder pad is switch pin 1, and pin 2 is horizontally adjacent to pin 1 (if the board is oriented long side vertical). I can see what appears to be a vertical trace between pins 1 and 3 if the orientation I've described is correct, but I want to make certain before I start soldering.
Thanks! Anything will fit if you hit it with a big enough hammer, so I wanted to be sure.
They actually fit in 2 orientations and you have to wiggle them in to seat them all the way down to the board
Behind on wrapping on the manual up, but will make sure to note it in there. Thanks!
