Odd considering others have had it. Maybe that is the issue
The "board type" field is grayed out on mine as well and was also for last year's show so I don't think there is anything you can do regarding that. It was a good suggestion though.
I still don't have mine working and the frustration and stress level is getting pretty high on my part. Argghh!
The differences between last years show with my ether-node controller and this year are:
1) This year I used Vixen3 and exported to a Vixen 2.1 sequence. The V2.1 sequence looks fine, it plays in Vixen 2.1 and I can use HNS to upload the sequence to my Helix Main and Ether-Node boards without any errors. I just don't get any pixels flashing.
2) Added an additional E682 board.
3) Added MANY more pixels so the vixen sequence channel count is >4,000 where last years overall channel count was ~300.
I've uploaded last years show to my Helix equipment and that works, so I'm guessing it has something to do with either using Vixen3 or the increased channel count.
I'll try to do a smaller sequence in Vixen3 to see if that has an effect and I'll also try copying nutcracker effects into a vixen2.1 sequence to see if that works.
Either way it is taking too much time, energy and sapping any sanity I still have left but thanks for the various suggestions.
at kiowamike, good luck to you. how did you program your sequences? Straight in Vixen 2 or did you use Vixen3 also?
