mheuer
New member
Hi all I am getting a similar error to above for the "Michael Myers (Theme from Halloween)"
If opening up the file in vixen v1 and saving it off to a different version works could somebody point me in the right directions.
Hello,
if that sequence works ok in Vixen 1.0, but causes those errors in Vixen 2.1, it might need to be converted to be used with Vixen 2.1.
This thread here describes some good methods for converting Vixen 1.x sequences to Vixen 2.
This is the method I use for conversion:
1: Download the older Vixen 2.0, and extract. (Only the 2.0 release can convert up directly from 1.x. You should use 2.1+ again once converted).
2: Copy the old v1 sequence into the newly extracted Vixen 2.0 'Sequences/' folder
3: Run the Prepare.exe file located in the newly extracted Vixen 2.0 folder
4: Done! The file should be converted for Vixen 2.x, and can now be copied into your Vixen 2.1 sequence folder for use
If you have trouble converting it, you could post a link here if you want.
Hope that helps,
Mike.
