Sean are we ever going to get garland like the original version? I thought it might be a good time to bring it up.
Not an effect - but I like to be able to attach digital sheet music for nutcracker/xlights to use instead of just relying on soundwaves
No teasing Dan, please post the settings screen shots so they can figure it out and play with it.
Spirals E_CHECKBOX_Spirals_3D=0,E_CHECKBOX_Spirals_Blend=0,E_CHECKBOX_Spirals_Grow=0,E_CHECKBOX_Spirals_Shrink=0,E_SLIDER_Spirals_Count=1,E_SLIDER_Spirals_Rotation=20,E_SLIDER_Spirals_Thickness=20,E_TEXTCTRL_Spirals_Movement=1.0 C_BUTTON_Palette1=#FFFFFF,C_BUTTON_Palette2=#FF0000,C_BUTTON_Palette3=#00FF00,C_BUTTON_Palette4=#0000FF,C_BUTTON_Palette5=#FFFF00,C_BUTTON_Palette6=#000000,C_BUTTON_Palette7=#00FFFF,C_BUTTON_Palette8=#FF00FF,C_CHECKBOX_Palette2=1 3100 5250 16 -1000
Spirals B_CHOICE_BufferTransform=Flip Horizontal,E_CHECKBOX_Spirals_3D=0,E_CHECKBOX_Spirals_Blend=0,E_CHECKBOX_Spirals_Grow=0,E_CHECKBOX_Spirals_Shrink=0,E_SLIDER_Spirals_Count=1,E_SLIDER_Spirals_Rotation=20,E_SLIDER_Spirals_Thickness=20,E_TEXTCTRL_Spirals_Movement=1.0 C_BUTTON_Palette1=#FFFFFF,C_BUTTON_Palette2=#7F0000,C_BUTTON_Palette3=#00FF00,C_BUTTON_Palette4=#0000FF,C_BUTTON_Palette5=#FFFF00,C_BUTTON_Palette6=#000000,C_BUTTON_Palette7=#00FFFF,C_BUTTON_Palette8=#FF00FF,C_CHECKBOX_Palette2=1 3100 5250 17 -1000
Spirals B_CHOICE_BufferTransform=Flip Horizontal,B_SLIDER_EffectBlur=5,E_CHECKBOX_Spirals_3D=0,E_CHECKBOX_Spirals_Blend=0,E_CHECKBOX_Spirals_Grow=0,E_CHECKBOX_Spirals_Shrink=0,E_SLIDER_Spirals_Count=1,E_SLIDER_Spirals_Rotation=20,E_SLIDER_Spirals_Thickness=20,E_TEXTCTRL_Spirals_Movement=1.0 C_BUTTON_Palette1=#FFFFFF,C_BUTTON_Palette2=#FF0000,C_BUTTON_Palette3=#00FF00,C_BUTTON_Palette4=#0000FF,C_BUTTON_Palette5=#FFFF00,C_BUTTON_Palette6=#000000,C_BUTTON_Palette7=#00FFFF,C_BUTTON_Palette8=#FF00FF,C_CHECKBOX_Palette2=1 3100 5250 17 -1000
Not really an effect... But the new layout screen you can double click a model and then drop a model multiple times.. Can this be added to the sequence tab so we can double click an effect and drop it multiple times??
Yep, ctl-c, ctl-v,ctl-v,...,ctl-v. Also one effect copied can be pasted to multiple cells
Sent from my iPhone using Tapatalk
Cells ? Does Nutcracker have a grid in this new version ?
Insteasd of fixed times like a grid in vixen 2 or lsp, we havetiming marks vertically and models horizontally.
If you had 16 arches and a timing mark from 5-10 seconds (100 frames at 20fps). Ctl-c an effect and then highlight those 16 cells and ctl-v to paste to it.
This has been true since early last year when xlights 4.0 was first released.
I consider it as having cells. When you create a sequence you specify a resolution, 25, 50, 100ms. The software basically creates cells at these intervals. You can't place effects at 25ms on a sequence created in 50ms. However, there aren't well defined (visually) cells in the sequencer. You can place timing marks to mimic a cell. You can very easily create a timing track at 50ms, so this will resemble what most people consider to be cells.
I've used sequencers with actual cells, this is way better!
James
With the advent of the p10 panels it would be nice to break up the panel into multiple virtual displays. The Idea being if you had a big panel you could break it up to display different things on each part. My main purpose of this is to get more then one singing face animation on the panel. I think this could be done in the layers by making picture that only cover a small portion but it would be nice to just use a standard picture so I can move faces around. The ability to break the model in half (left, right or Up down) or into 4 would be awesome.
I can't right click very easy on a MacBook. But I was just a suggestion would make it very easy to drop effects multiple times.
