davedecali
New member
Sent from my iPhone using Tapatalk
Glad you figured out what I was saying. Not sure I even understood. You can drill the rivets out. My current enclosure weights a ton and 1/4" plexiglass isn't helping. $112 bucks for a 4x8 sheet. If I go with the aluminum from I scrap the glass. Ugh! But, if I can cut the weight by a fourth it's probably worth it because I'm mounting this over the garage and it's easily 9-10 feet off the ground.Hahaha... I was picking it up. But yeah you should be good. I haven't installed any plexi into the front channel but realized after I riveted the corners on, so I would use screws on the corners.
