DrNeutron
Active member
No, life got in the way and I was remiss. You should have gotten a shipping notice today.
No problem.
Thanks for update.
No notices as of today.
***************Moved to new topic***********
I got my boards and soldered a few together. I have a question on usage. I used some SPT-1 and put the FWC board in a short extension cord with M/F Vampire Plugs so I did not have to cut the lights yet. I plugged in the FWC extension then plugged in my light set and the flicker is gone.
The lights I am plugging in are 120 LED Icicle lights from Rite Aid. I get the first segment lit then an unlit section then another lit section and a final unlit section. I understand I will have to swap the + and - on the second half of a 2 section string so it fully lights but what do I need to do on a string with 4 segments? Do I cut/swap/splice in between both lit and unlit sections? If I flip the + and - between the first and second segments what will happen to the next 2 sections?
Thanks
Never got the notice but the boards showed up this week.Did you get a notice yet?
Yup, Just did my first set and had to splice it 3 times.
Thanks again for the response.
Mark
Am I correct in thinking that these could be installed in the pigtail off the controller and not on the cord itself? I understand the swapping polarity in the 2 wire section but why not install these at the pigtail and not the light strand? Any problem doing it that way? Thanks, Ray.
I am having a problem with the FWC. This is my first year doing anything other then a static display, so I am a newb to this. I have soldered two of them so far and every time I plug them in, I am blowing the small fuses in the plug. I don't think it is my soldering as I have put together six EsPixelsticks together with no problems. Could still be my soldering I guess. Mine look just like the ones in the pictures The only thing I can figure is I am putting the power plug on the wrong end?
Does anybody have a picture of a string without shrink on it? I am curious what side the power plug goes on? I have looked in the forum for detailed instructions, but haven't found them.
Thanks!
Mark
Great, glad they showed up. Guess that is more important than the email.Never got the notice but the boards showed up this week.
That's how I did mine. Only problem would be if you had a lot of LEDs. The diodes in the FWC are rated at 1 amp, each section of LEDs is generally .02 amps. I wouldn't want to go above about .5 amps - This means a limit of about 25 sections on an FWC (or SSS) board.Am I correct in thinking that these could be installed in the pigtail off the controller and not on the cord itself? I understand the swapping polarity in the 2 wire section but why not install these at the pigtail and not the light strand? Any problem doing it that way? Thanks, Ray.
Thanks!
