CaptainMurdoch
New member
Is there anyone around who has a Raspberry Pi with the Falcon Player, a LEDTriks with Triks-C, and a USB serial dongle to connect the Triks-C to the Pi running the Falcon Player?
I have an idea for the Falcon Player that I want to explore that would let you drive a LEDTriks w/ Triks-C as a monochrome matrix using regular sequence data. This would allow you to sequence your LEDTriks display in any sequencer that understands how to work with a matrix such as Nutcracker, Vixen 3, HLS, etc..
I'd like to provide a test perl script to run on the Pi. It would basically draw a frame of data onto the LEDTriks display. If that test script worked then I could look at adding the rest of the glue to allow the Triks-C to receive data from the Falcon Player.
