Renard64
Revision as of 05:58, 10 August 2008 by Wayne J (talk | contribs)
Media:Renard64_sch_002.pdf
Layout
Important Note: The entire solder side of the PCB is a ground plane, which will tend to absorb and redistribute heat. It is highly recommended that you use a good, temperature controlled soldering iron to assemble the board. Ordinary pen-style soldering irons may not get hot enough to make good solder connections, especially to pins that connect to the ground plane.
XA PCB
Picdimmer forum thread
XB PCB
COOP PCB V2.0
There are several alternatives listed below for providing a zero-crossing signal. The first choice is listed as preferred, because that is the selection that works with the Ren-T board. The second alternative is OK (requires an external low-voltage transformer). The third alternative will work also, but its use is discouraged because it requires that 110VAC be brought onto the controller board.
PCB
1  TBA                   Renard 64-Port PCB
Resistors
3  299-27K-RC            27K Resistor, 1/8 W, Axial (RS485 pull)     R5,R8,R14
2  299-1K-RC             1K Resistor, 1/8 W, Axial (RS485 series)    R4,R7
1  660-MF1/4DCT52R1200F  120 Resistor, 1/4 W, Axial                  R6
1  299-330-RC            330 Resistor, 1/8 W, Axial (for power LED)  R19
Capacitors
8  80-C322C104K5R        0.1 uF Radial-lead Ceramic Capacitor        C3-C10
1  647-UVR1C470MDD       47 uF, 16V Radial-Lead Elect. Cap           C2
Diodes
1  78-1N5229B            4.3v 0.5w Zener                             D4 (left)
1  78-1N5239B            9.1v 0.5w Zener                             D5 (near R5 on XB) or D4 (right, on XA)
1  604-WP7104GT          T1 Green LED                                D5 (near U11)
Connectors
2  571-5202514           AMP Modular Jacks, Right Angle              J3, J4
16 538-95003-2881        Molex Modular Jacks, Vertical PCB mount     J5-16, J18-21
1  571-640454-2          AMP Polarized Header (2-Pin, Straight Post) J17
8  575-199314            14 Pin Low Profile IC Socket                U7-U14
1  571-1032393           3-Pin Straight Header                       J2
1  151-8000              2-Pin Shunt                                 J2
1  538-70543-0002        3-Pin Shrouded Header (see notes 1-3 below) U1
1  538-50-57-9403        3-Pin SL Connector (mate to preceding item) XU1
3  538-16-02-0103        Crimp Terminals, Female, 22-24AWG, 15μ Au   XU1
ICs
2  511-ST485BN           RS485 Connectors                            U4,U5
8  579-PIC16F688-I/P     PIC16F688, unprogrammed, DIP14, Industrial Temp    U7-14
Oscillator
1 520-TCH1843-X          Oscillator, 18.432 MHz, 5V, 8-DIP           U3
ZC Alternative 1 (if zero-crossing is brought in on J17 or through J3/J4, preferred)
1  299-10K-RC            10K Resistor, 1/8 W, Axial                  R9
1  512-2N3904TFR         2N3904 Transistor                           Q1
ZC Alternative 2 (if 12VAC is brought into J1 as the zero-crossing source)
1  782-H11AA1            Optoisolator                                U6
2  299-1.5K-RC           1.5K Resistor, 1/8 W    Resistor            R1,R2
ZC Alternative 3 (if 110VAC is brought into J1 as the zero-crossing source, discouraged).
2  71-CCF60-15K-E3       15K Resistor, 3/4 W, MF Resistor            R1,R2
Optional (if per/port LEDs are desired)
64 859-LTL-403G          LEDs, Rectangular, Green
8  652-4608X-1LF-680     Resistor Network, 680 Ohm, 8-Pin, Bussed    R10-13, R20-23
8  299-680-RC            Resistor, 680 Ohm, 1/8W                     R15-18, R24-27
Optional (if using on-board regulator with unfiltered power brought in through J4, see note 1 below)
1  625-1N5819-E3         50v 1A Schottky Diode                       D1
1  511-L4940V5            Regulator, LDO, 5V, 1.5A                    U1
1  140-XRL16V1000-RC     1000 uF, 16V Radial-Lead Elect. Cap         C1
Note 1: The on-board regulator should only be used if measures are taken to keep the current consumption down (omitting the on-board LEDs, and using the non-PWM firmware). If the LEDs are used and the PWM firmware is installed, the current consumption of the board is about 1A, and so the regulator will dissipate too much power (the small value of C1 precludes decreasing the input voltage). If you are using an external PC power supply, you don't need these optional parts.
If the on-board regulator is used, omit the header that is designated for U1.
Note 2: The specified connectors for bringing in external power are 15μ Gold, you may change this if you have other preferences. Also, the molex calls for using a crimp tool. The ones in the mouser catalog are pretty expensive, and I don't know how well the Radio Shack ones will work.
Note 3: An alternative to the Molex power connectors is to use a modified, spare IDE disk drive Y-cable (or similar) as a pigtail from the board.
 7/21/2007 BOM copied from picdimmer forum, on-board regulator made optional
 7/21/2007 Value of regulator parts (diode, regulator, cap) changed.
 7/21/2007 Value of LED current limit resistors changed.
 7/22/2007 Changed p/n of TYCO/Amp vert. mount connector to ROHS, added note about physical size problem with them.
 7/24/2007 Deleted TYCO/Amp vert. mount jacks, they don't fit.  Use the Molex Jacks instead.
 7/24/2007 Changed value of C2, to agree with datasheet for regulator even at low temperatures.
 8/07/2007 Change vendor, pn for optional 680 Ohm resistor network to one that is more readily available.
 8/07/2007 Change description of 299-series resistors (previously had the wrong power rating).
 8/07/2007 Created two zero-crossing alternatives.
 8/12/2007 Added new zero-crossing alternative (the new alternative 2)
 8/27/2007 Added Two 3-Pin headers (for J2, U1) and a 2-pin shunt (J2).
 9/02/2007 Changed two part numbers (added dashes), modified note regarding on-board regulator.
 10/01/2007 Changed part numbers for power connector, added notes regarding that.
 10/01/2007 Fixed incorrect p/n for 3-pin header.
 12/13/2007 Fixed part number on voltage regulator.
Construction Notes
1) The '+' leads of C1 and C2 go in the holes with the square pads.
2) The anodes of the status LEDs (long lead) go in the holes with the square pads.
3) The cathodes (the end with the band) of diodes D1, D4, and D5 go in the holes with the square pads.
4) The pin with the dot above it on the resistor network component should be installed in the square hole.
Errata for Rev XA PCB
 1) The trace between J4 and D1 is too small, and needs to be beefed up if the board is configured to draw more than 1/2A through J4.
 2) There are two diodes labeled D4.
 3) The holes for D1 are too small.
 4) The silkscreen reference designator for C3 (above U10) is missing.
XC PCB Current release
The first prototype, with some parts still to be fitted. Tested on Jan 20, 2008.
Media:Renard64_xc.pdf
Layout Image
Note: This BOM does not include a transformer, power cords or connectors for the primary side of the transformer.
PCB
Resistors
2  299-750-RC            750 Resistor, 1/8 W, Axial                  R1,R2
1  660-MF1/4DCT52R1200F  120 Resistor, 1/4 W, Axial                  R3
Capacitors
1  140-XRL16V6800-RC     6800 uF, 16V Radial-Lead Elect. Cap         C1
Diodes
4  625-1N5817-E3         Schottky Diode (20V, 1A)                    D1-D4
1  78-1N5229B            4.3v 0.5w Zener                             D5
1  78-1N5239B            9.1v 0.5w Zener                             D6
1  604-WP7104GT          T1 Green LED                                D7
Connectors
2  571-5520251-4         AMP Modular Jacks, Right Angle              J3, J4
16 571-5556416-1         AMP Modular Jacks, Vertical PCB mount       J5-16, J18-21
1  636-182-009-213R531   Norcomp DE9 Female Rt Angle D-sub Conn      J22
1  538-22-03-2021        Molex PCB Header 2-pin                      JP1
1  151-8000              2-Pin Shunt                                 JP1
2  534-4902              Male Sturdi-mount Terminal                  Tab1, Tab2
2  159-2215              Vinyl Insulated Couplers (Female)           Tab1, Tab2
ICs
Oscillator
XC revision History
2008/01/21  PJS DE9 connector (J22) added to BOM
2008/01/25  PJS changed value of R1, R2 to 750 Ohm (was improperly calculated for 6.3VAC input).
2008/02/18  PJS changed value of C1
