- Pixel Controllers
- Dumb RGB Controllers.
- E1.31 (DMX over Ethernet)
- Advanced Features
- Etc.
PIXEL CONTROLLERS
Open Lighting Architecture
OLA can be used on a Raspberry Pi, Beagle Bone Black or other single board computers with SPI. It can receive E1.31 (and many other protocols) and use the data to drive SPI pixels. See https://wiki.openlighting.org/index.php/OLA_LED_Pixels for more information. The maximum pixel count is determined by the hardware and the pixel clock speed. Demo Video.
HolidayCoro
Default IP Address is 192.168.0.50 (configurable via LCD interface or webpage) or can be configured for DHCP.Model | Max Pixels | DMX Universes | Pixels Supported | Output Connectors | String Outputs | Image | Link / Price | Setup Videos | Note |
AlphaPix 4 V3 |
2,720 | 16 UniCast (E1.31 & Artnet) | WS2811,WS2812,WS801,WS2803 TM1804,TM1803,TM1812,SM16715 TLS3001,TLS3002,CY3005 LPD6803,D705,LPD1101 |
$99.95 Bare Controller $199.95 Ready2Run with PSU, Enclosure, Cables |
Demo Video Setup Videos |
Includes one dedicated RS-485/DMX output (does not use a pixel output), 28A per Controller/7.5A per Output, LCD Display for Configuration and Testing, WEB Interface for configuration and monitoring, Adapter mounting plates for CG1500 enclosure available, built-in voltage and temperature sensor allow remote controller monitoring along with the built-in fan controller for cooling the enclosure. | |
AlphaPix 16 V3 |
5,440 | 32 UniCast (E1.31 & Artnet) | WS2811,WS2812,WS801,WS2803 TM1804,TM1803,TM1812,SM16715 TLS3001,TLS3002,CY3005 LPD6803,D705,LPD1101 |
$1899.95 Bare Controller $319.95 Ready2Run with PSU, Enclosure, Cables |
Includes three dedicated RS-485/DMX outputs (does not use a pixel output), 30A per Bank, 2 Banks per Controller (60A Total)/5A per Output (80A at 20% Duty Cycle), LCD Display for Configuration and Testing, WEB Interface for configuration and monitoring, Adapter mounting plates for CG1500 enclosure available, built-in voltage and temperature sensor allow remote controller monitoring along with the built-in fan controller for cooling the enclosure. Resistor bank for outputs to reduce likely hood of shorting upon incorrect connections. |
Advatek Lighting Pty Ltd
(Australia Based run by DIYC user Unknown (Devo))
PixLite 4 | 2,720 | 16 UniCast 16 MultiCast |
WS2811,WS2812,WS801,WS2803 TM1804,TM1803,TM1812,SM16715 TLS3001,TLS3002,CY3005 LPD6803,D705,LPD1101 USC6909,UCS6912,SM16716,MBI6020 |
MFG Product Link US Re-Seller Link |
Assembled $119.95 | Manual |
Includes one dedicated RS-485/DMX output, 28A per Controller/7A per Output, Gamma Correction, Temp & Power Monitor | |
PixLite 16 | 5,440 | 32 UniCast 32 MultiCast |
Assembled $199.95 | Manual |
Includes four dedicated RS-485/DMX outputs (does not use a pixel output), 30A per Bank, 2 Banks per Controller (60A Total)/4A per Output, Gamma Correction, Temp & Power Monitor |
SanDevices
Model | Max Pixels | DMX Universes | Pixels Supported | Output Connectors | Max Channels | DMX Universes per Output | Image | Link | Price | Manual | Note |
E6804-4 | 2040 | 7Multicast / 12Unicast | GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others | 4 Fused (1x4 Electrical, 4x1 Logical) | 6120 | Up to 12 | link | Assembled/Tested: $99, Full Kit: Price $69 Presale | Owner's Assembly | Size is 2.5" x 4", mounting holes on 2"x3" centers, compatible with CG series enclosures. Announcement | |
PS-1 | 1020 | 6Multicast | GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others | 16 Fused (2x8 Electrical, 4x4 Logical) | 3060 | Up to 6 | link | Turnkey System: $399 | Owner's | Assembled E682 with power supply in an Enclosure | |
E682-12 | 2040 | 6Multicast / 12Unicast | GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others | 16 Fused (2x8 Electrical, 4x4 Logical) | 6120 | Up to 12 | link | Assembled/Tested: $180, Full Kit: Price $109 | Owner's Assembly | To be released shortly | |
E682-6 | 1020 | 6Multicast | GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others | 16 Fused (2x8 Electrical, 4x4 Logical) | 3060 | Up to 6 | link | Assembled/Tested: $180, Full Kit: Price $109 | Owner's Assembly | Original E682, Before Firmware Upgrade | |
E681-12 | 2040 | 6Multicast / 12Unicast | GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others | 16 Fused (2x8 Electrical, 4x4 Logical) | 6120 | Up to 12 | link | No Longer Available | Owner's Assembly | Firmware To be released shortly, requires UP1 upgrade | |
E681-6 | 1020 | 6Multicast | GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others | 16 Fused (2x8 Electrical, 4x4 Logical) | 3060 | Up to 6 | link | No Longer Available | Owner's Assembly | Original E681, with Firmware Upgrade and UP1 upgrade | |
E681-4 | 680 | 4Multicast | GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others | 16 Fused (2x8 Electrical, 4x4 Logical) | 2040 | Up to 4 | link | No Longer Available | Owner's Assembly | Original E681, without Firmware Upgrade and without UP1 upgrade | |
E680-12 | 2040 | 6Multicast / 12Unicast | GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others | 16 Fused (2x8 Electrical, 4x4 Logical) | 6120 | Up to 12 | link | Partial Kit: $19 (PC Board + EEPROM) needs additional parts to function | Owner's Assembly | To be released shortly, requires UP1 upgrade | |
E680-6 | 1020 | 6Multicast | GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others | 16 Fused (2x8 Electrical, 4x4 Logical) | 3060 | Up to 6 | link | Partial Kit: $19 (PC Board + EEPROM) needs additional parts to function | Owner's Assembly | Original E680, with Firmware Upgrade and UP1 upgrade | |
E680-4 | 680 | 4Multicast | GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others | 16 Fused (2x8 Electrical, 4x4 Logical) | 2040 | Up to 4 | link | Partial Kit: $19 (PC Board + EEPROM) needs additional parts to function | Owner's Assembly | Original E680, without Firmware Upgrade and without UP1 upgrade |
PixelController.com (Falcon Christmas)
Default IP Address is 192.168.1.50. Can be configured via OLED interface or webpage. Supports DHCP (Dynamic Host Configuration Protocol).Model | Max Pixels | DMX Universes | Pixels Supported | Output Connectors | String Outputs | Image | Link | Price | Note |
F16V2 | 10,880 | 64 Multicast/Unicast (E1.31) | WS2811,WS2812,WS801,WS2803 TM1804,TM1803,TM1812 GECE TLS3001,TLS3002,CY3005 LPD6803,D705,LPD1101 |
16/32 Fused Outputs Screw Terminals |
16/32 Outputs 680 Pixels Per Output (340 when in 32 port mode) |
Store | Assembled $200.00 | 5-32V DC, Every port can be a different type. Expandable to 32 ports, soon to be 48 ports. Virtual string support. 40Hz refresh rate on outputs even when pixel count is 680 pixels. Includes four dedicated RS-485/DMX outputs, 30A per Bank, 2 Banks per Controller (60A Total)/5A per Output, OLED Display for Configuration and Testing, Webpage Interface, Mounting plate for CG1500 enclosure available. Voltage and temperature sensors. OLED E131 diagnostic tools. 4 - Renard (Speed and stop bits configurable), DMX and Pixelnet Outputs. |
Joshua 1 Systems (J1SYS)
ECG-P12R | 2040 | 12Unicast | LPD6803, WS2801, WS2811, TM180x, TLS3001 | 12 Fused (2x6 Electrical, 3x4 Logical) | 6120 | 1 | link | Assembled Board: $175 | Owner's Notes | ||
ECG-PIXAD8 | 1360 | 8Unicast | LPD6803, WS2801, WS2811, TM180x, TLS3001 | 8 Fused (2x4 Electrical, 2x4 Logical) | 4080 | 1 | link | Assembled Board: $155 | Owner's | ||
ECG-P2 | 1360 | 8Unicast | LPD6803, WS2801, WS2811, TM180x, TLS3001 | 2 Unfused (2x1 Electrical, 2x1 Logical) | 4080 | 4 | link | Assembled Board: $75, Assembled Board w/case: $85 | Owner's |
DMX512 / ESTA 1.11 (RS485) to SPI
HolidayCoro
Model | Max Pixels | DMX Channels | Pixels Supported | Output Connectors | Image | Link | Price | Note |
EasyPix V2 | 170 | 512 | WS2811,WS2812,WS801,WS2803 TM1804,TM1803,TM1812,SM16715 TLS3001,TLS3002,CY3005 LPD6803 |
Product Link | $39.99 | Null pixels, Reverse order,Push button setting with back-lit LCD screen, built-in sequences, replaceable output chip |
DCG-P2 | 170/680* | 1DMX/*4HyperDMX | LPD6803, WS2801, WS2811, TM180x, TLS3001 | 2 Unfused (1x2 Electrical, 1x2 Logical) | 512DMX/*2048HyperDMX | 1 | link | Assembled Board: $53 | 2 Pixel Outputs share 1 DMX or 4 HyperDmx input channels | ||
uDCG-P2 | 170/680* | 1DMX/*4HyperDMX | LPD6803, WS2801, WS2811, TM180x, TLS3001 | 2 Unfused (1x2 Electrical, 1x2 Logical) | 512DMX/*2048HyperDMX | 1 | link | Assembled Board: $42, Assembled Board w/Case: $48 | 2 Pixel Outputs share 1 DMX or 4 HyperDmx input channels |
Ray Wu
(China Based)
DIYB
Electron Design
(Israel based)
AVD
ACL
Onumen
RPM
Stellascapes
- T3: DMX512 - SPI Bridge
SD Memory Card to SPI
Ray Wu
(China Based)
Light-O-Rama (LOR) to SPI
Light-O-Rama (LOR)
(USA Based)
PIXEL Extenders
- ECG-PPX
E1.31 Bridges and DMX Dongles
DIYLEDEXPRESS
RPM
USB to DMX512 Output
- Enttec Open DMX USB
- Enttec DMX USB Pro
- RPM DIY USB to DMX Adaptor
- RJ's LYNX DMX DONGLE
FTDI drivers for dongles:
- FTDI VCP Drivers
Manufacturer | Model | Pre-built | DC Voltage | Channels | Channel Current | Total Current | Protocol(s) | Total Price | Per Ch Price |
HolidayCoro | #27 / Water Resistant / Boxed / Pigtails / 9 Test Sequences | Yes | 6V - 24V | 3 | 2A | 6A per 3 Ch | DMX | $9.49 | $3.16 |
Light-O-Rama | CMB16D | Yes | 5V - 60V | 16 | 4A | 20A per 8 Ch | LOR, DMX | $119.95 | $7.49 |
Light-O-Rama | CMB16D-QC | Yes | 5V - 60V | 16 | 4A | 20A per 8 Ch | LOR, DMX | $99.95 | $6.24 |
TigerDMX | TigerDMX48 | Yes | 9V - 55V | 48 | 2.5A | 30A per 24 Ch | DMX | $145.00 | $3.02 |
TigerDMX | TigerDMX120LC | Yes | 12V - 36V | 120 | 100mA | DMX | $125.00 | $1.04 | |
AVD | DC48 | Yes | 12V - 36V | 48 | 2A | 20A per 24 Ch | DMX | $199.00 | $4.15 |
AVD | DC24 | Yes | 12V - 36V | 24 | 2A | 15A per 12 Ch | DMX | $129.00 | $5.38 |
Audiolight Intl | HD-714 US China | Yes | 12V - 24V | 3 | 2A | 6A | DMX | $8.95 | $2.98 |
Audiolight Intl | HD-712 US China | Yes | 12V - 24V | 27 | 1A | 15A | DMX | $44.21 | $1.64 |
Leynew | LN-DMXMODEL-3CH-LV12 US China | Yes | 12V | 3 | 2A | 6A | DMX | $7.49 | $2.49 |
EUChips | PX24506 | Yes | 12V - 24V | 3 | 3A | 9A | DMX | $22.32 | $7.44 |
wjohn | DMX3 | No | 9-35vdc | 3 | 2A per Chn | up to 6A | DMX | $9.00 | $3.00 |
wjohn | DMX16DCSSR | No | 12-24vdc | 16 | 2A per Chn | up to 10A | DMX | $48.00 | $3.00 |
wjohn | REN64 | No | 9-35vdc | 64 | 2A per Chn | up to 7A per SSR | RS232/485, DMX | $67.50 | $1.05 |
Renard | Ren48LSD | No | 5,9-24vdc | 48 | 400mA | 9.6A x 2 | RS232/485, DMX | $44.66 | $0.93 |
DIYLEDExpress | Ren24DC | Built or Kit | 5,7-24vdc | 24 | 4A | 30A x 2 | RS232/485, DMX | $72.10 | $3 |
Different Styles of Pixels
Waterproofing Pixels
Null Pixels
