Advanced Channel Management
Revision as of 04:35, 22 February 2013 by Jlowe (talk | contribs) (→‎Using Folders)
This is based on version 12K.
Figure 3-10
  • Left-most Gray Square: This is a selection box. You left-click in here and the square becomes green. That channel (and any others you left-click on) is selected and can be moved into a folder or deleted.
  • Name: This field shows the name of the channels.
  • Universe: A numerical value from 0-5000. Any channels in universe 0 will never be displayed.
  • Channel: This is the numeric value of the channel. These are used when the sequence is sent to controlling hardware. This will remain zero until they are setup in the "output" section.
  • Color: This field is set to the color of the channel.
  • RGB: This checkbox is checked when a channel is an RGB lighting element or pixel.
  • Dimming Curve: This field is to set a dimming curve for the channel.
  • Order: This field is used to adjust the order of the channels.
  • Folder: The number of the folder that a channel is assigned to.
  • Control Type: This is used with animation effects and trigger events.
  • GRB: Used when the order of the RGB is different from Red-Green-Blue.
  • Preview Group: This group number defines what Preview Group the channel belongs to.
  • Preview Number: This is the channel number for the assigned display group.
  • Display X / Display Y: These numbers are calculated by using the Display Preview and allow the user to plot pixels on an X/Y axis which will allow controlled effects such as color sweeps from left to right or top to bottom. (This is not yet fully implemented.)
Advanced Renaming Channels
Figure 3-11
Rename Individual Channels:
  • Check the box to Unfreeze Name to Edit.
  • Click on the channel you wish to rename.
  • Highlight the old name and type in the new name.
  • When done, Click Done with Changes.
Figure 3-12
Bulk Channel Renaming:
Method One:
  • This is the more straight-forward and basic method of bulk renaming.
  • Highlight the cells you wish to rename
  • Formula: Name_(StartingChannelNumber)
  • This will rename channels with "Name" shown except replace (StartingChannelNumber) with a sequential number starting at the number specified.
  • Examples:
    • "MTString_(1)" will produce MTString_0001, MTString_0002, etc.
    • "Yard_(15)" will produce Yard_0015, Yard_0016, etc.
Method Two:
  • This method is likely to be used when renaming large groups of pixels or strings.
  • Formula: @NumberOfPixels, Name(*StartingStringNumber)_%
  • This will rename channels with "Name" shown, followed by the value of "StartingStringNumber", and then counting UP until reaching the "NumberOfPixels" value.
  • Once reaching the "NumberOfPixels" value, the value of "StartingStringNumber" will increment by 1, and the "NumberOfPixels" will start counting upwards from 1 again.
  • Example: A pixel megaTree with 32 strings composed of 42 pixels each:
    • @42,MTString(*1)_% will rename channels with values of MTString01_0001 to MTString32_0042
Reordering Channels
Figure 3-13
To ReOrder channels:
  • Select the channels you wish to move.
  • In the ReOrder Specific Channels field (See Figure 3-13), enter a number that does not conflict with existing channels and then click ReOrder Channels.
  • Once the channels have been ReOrdered, click Refresh After Order Change to update the Order column.
  • Example: To move 5 channels from the beginning to the end:
    • Highlight the five channels to move.
    • In the ReOrder Specific Channels field, enter a number that is higher than the last channel's Order number.
    • Click ReOrder Channels.
    • Click Refresh After Order Change.
  • Example: To move 5 channels from the bottom to the top:
    • Highlight all channels EXCEPT the five channels to move.
    • In the ReOrder Specific Channels field, enter a number that is higher than the last channel's order number.
Using Folders
Figure 3-14
Create a New Folder:
Figure 3-15
Figure 3-16
  • Open the Channel Manager (Manage Channels -> Manage Raw Channels).
  • Click the Add Folder button on the top toolbar. (See Figure 3-14).
  • A dialog box will open asking for a Folder name. Type name and press OK. (Se Figure 3-15).
    • Note: A Super Folder contains only folders. Check this box if you wish to create a "folder of folders". This would be used for channel organization.
  • Once entered, the folder will appear at the top of the list of channels and have ++ on the left-most square to identify it as a folder. (See Figure 3-16).
Figure 3-17
Figure 3-18
  • Highlight the channels you want to add to a folder.
  • Press the Copy to Folder button.
  • This will turn the left-most square GREEN for selected channels.
  • Tip: You can also select channels by left-clicking on the square to turn it green.
  • Once all channels are selected (left-most square green), press the Paste to Folder button. This will turn from red-to-green. (See Figure 3-17, 3-18).
  • Click on the left-most square of the folder you want to move the channels into. This will move the channels into the desired folder.
Remove channels from a folder:
  • Click the folder name to expand the items.
  • Select the channels to remove by clicking the left-most square and turning it green (or, highlighting rows to remove).
  • Press the Remove from Folder button.
Opening and Closing Folders:
  • To open a folder, simply click on the name of the folder.
  • To close a folder, click on the name of the folder.
  • To open ALL folders, click the Expand All Folders checkbox.
VIDEO: Joe describes folders and folder management
Copying Channels
Figure 3-19
Figure 3-20
To copy multiple channels click on the first channel to be copied and asterisks will appear to the left of the channel name. The without clicking move your mouse down to include all of the channels you would like to copy (see Figure 3-20). Asterisks will appear to the left of the channel to be copied. Once you have selected all of the channels to be copied click again on the last channel to be copied to select all of them.
Deleting Channels
  • To remove channels, open the Channel Manager (Manage Channels -> Manage Raw Channels).
  • Highlight the channels to delete by clicking and dragging into the data fields.
Figure 3-21: Click the Delete Selected Channels button.
Figure 3-22: Confirm you wish to delete by clicking yes.
Figure 3-23: HLS will prompt to shut down to update its configuration. Click OK. Then OK again.
Program Help File
Setting up HLS Channels Chapter 3: Channel Management RGB Channels
