Converting Three Channel Red, Green, Blue channels Into a Single RGB Channel
1A also contains a three channel - Red, Green, Blue - conversion into a single RGB channel. This should help reduce channel count from a converted Vixen file.
The way to do the RGB conversion follows: Add your RGB channels to your sequence. Create a group that contains a few of your new RGB channels and their associated single channels.
Under the Menu "Manage Channels" - select "Convert Three Channels to RGB". Note the warning about overlapping channels - you can manually clean those up later. Perform the conversion.
When you are happy with the conversion - go into "Manage Raw Channels" and DELETE the three single channels - NOTE - they will not be removed until you close HLS down. Close HLS - then restart HLS. Conversion is now complete and old channels are gone leaving only single RGB for you to sequence with.
Next: Converting Vixen Files to HLS
