Main public logs
Combined display of all available logs of doityourselfchristmas.com. You can narrow down the view by selecting a log type, the username (case-sensitive), or the affected page (also case-sensitive).
- 19:22, 6 June 2013 Phil Short talk contribs uploaded File:Renard-px1 RevE.PNG
- 16:16, 6 June 2013 Phil Short talk contribs uploaded File:Renard-px1 RevE sch.PNG
- 18:08, 2 November 2011 Phil Short talk contribs uploaded File:LEDancer-20111101.asm
- 18:02, 2 November 2011 Phil Short talk contribs uploaded File:LEDancer-revA.png
- 17:53, 2 November 2011 Phil Short talk contribs uploaded File:LEDancer2.PNG
- 19:28, 27 May 2011 Phil Short talk contribs uploaded File:LEDancer1.png
- 19:13, 27 May 2011 Phil Short talk contribs uploaded File:LEDancer PCB Example1.png
- 18:22, 27 May 2011 Phil Short talk contribs uploaded a new version of File:Ledancer-20110527.asm
- 18:19, 27 May 2011 Phil Short talk contribs uploaded File:LEDancer-20110527.asm
- 18:16, 27 May 2011 Phil Short talk contribs uploaded File:Ledancer-20110527.asm (Changes to the comments...)
- 15:33, 22 May 2011 Phil Short talk contribs uploaded File:LEDancer-20110522.asm
- 15:14, 22 May 2011 Phil Short talk contribs uploaded File:LEDancer-20110521.asm
- 05:02, 22 May 2011 Phil Short talk contribs uploaded File:LEDancer LED SCH.png
- 04:59, 22 May 2011 Phil Short talk contribs uploaded File:LEDancer LED SCH.PNG
- 04:49, 22 May 2011 Phil Short talk contribs uploaded a new version of File:LEDancer.PNG
- 04:34, 22 May 2011 Phil Short talk contribs uploaded a new version of File:LEDancer PCB Example.png
- 04:22, 22 May 2011 Phil Short talk contribs uploaded File:LEDancer PCB Example.png
- 04:15, 22 May 2011 Phil Short talk contribs uploaded File:LEDancer LED Module.PNG
- 04:08, 22 May 2011 Phil Short talk contribs uploaded File:LEDancer.png
- 04:05, 22 May 2011 Phil Short talk contribs uploaded File:LEDancer.PNG
- 17:16, 29 October 2008 Phil Short talk contribs moved page 一ç ä¸ç‰¹ä¸åŽä»˜æ¬¾æ„¿æ„当汤圆 to Junk6
- 17:15, 29 October 2008 Phil Short talk contribs moved page 香港å…åˆå½©ç‰¹ç ä½ çŸ¥é“å—? to Junk5
- 17:12, 29 October 2008 Phil Short talk contribs moved page 香港å…åˆå½©æ›¾é“人主一肖必ä¸ç‰¹ç 已公开 to Junk4
- 17:11, 29 October 2008 Phil Short talk contribs moved page 分外甜蜜 香港å…åˆå½© to Junk3
- 17:10, 29 October 2008 Phil Short talk contribs moved page 香港å…åˆå½©ç‰¹ç 内幕资料在这里www.188598.com to Junk2 (spam)
- 17:07, 29 October 2008 Phil Short talk contribs moved page 一ç ä¸ç‰¹ä¸åŽä»˜æ¬¾ to Junk1 (Apparently spam)
- 21:20, 9 January 2008 Phil Short talk contribs uploaded File:Renard64 xc.pdf (XC rev schematic, as the board went out for proto. Schematic manually created after the fact, so take it with a grain of salt.)
- 21:18, 9 January 2008 Phil Short talk contribs uploaded File:Renard64 xc5b.gif (PCB as it went out for proto.)
- 21:07, 8 December 2007 Phil Short talk contribs uploaded File:Grinch pcb assembled.jpg
- 02:21, 7 November 2007 Phil Short talk contribs uploaded File:Pickit ad hoc socket.gif
- 01:26, 24 October 2007 Phil Short talk contribs uploaded File:Renard-20071023.asm (Beta test code...changes in attempt to reduce flickering at low dimmer levels with LED strings.)
- 04:03, 12 October 2007 Phil Short talk contribs uploaded File:Renard64 sch 002.pdf
- 03:56, 12 October 2007 Phil Short talk contribs uploaded File:Renard64 sch 002.pdf (Updated schematic (schematic-only errors fixed).)
- 02:26, 6 September 2007 Phil Short talk contribs moved page Runescape gold and money to Junk to delete
- 03:24, 31 August 2007 Phil Short talk contribs uploaded File:Ren-diag-20060905.asm
- 00:19, 29 August 2007 Phil Short talk contribs uploaded File:Renard64 layout XB.gif
- 23:54, 18 August 2007 Phil Short talk contribs uploaded File:Ren-diag-20070815a.asm (Renard diagnostics firmware - uses external 18.432 MHz oscillator)
- 21:19, 17 August 2007 Phil Short talk contribs uploaded File:Xformer ct.gif (Revised Drawing - center-tapped transformer with rectifier)
- 21:07, 17 August 2007 Phil Short talk contribs uploaded File:Xformer conn2.gif (Transformer Connections using a center-tapped transformer)
- 21:07, 17 August 2007 Phil Short talk contribs uploaded File:Xformer conn1.gif (Connections when using regular transformer)
- 20:37, 17 August 2007 Phil Short talk contribs uploaded File:Sinewave rect.gif (Unlabelled rectified sine waveform (abs(sin(wt)))
- 20:36, 17 August 2007 Phil Short talk contribs uploaded File:Sinewave nolabel.gif (Unlabelled Sine Waveform)
- 20:26, 17 August 2007 Phil Short talk contribs uploaded File:Xformer ct.GIF (Schematic of a center-tapped schematic with a two-diode full-wave rectifier)
- 20:25, 17 August 2007 Phil Short talk contribs uploaded File:Xformer regular.GIF (Schematic of a simple transformer with a full-wave bridge rectifier)
- 00:25, 14 August 2007 Phil Short talk contribs moved page Display Construction Techniques to Display Construction
- 00:21, 14 August 2007 Phil Short talk contribs moved page Hardware to Electronics Hardware (Upper level reorganization)
- 00:15, 14 August 2007 Phil Short talk contribs moved page How To articles to Display Construction Techniques (Better Organization)
- 17:28, 30 June 2007 Phil Short talk contribs uploaded File:Renard64 sch 001.pdf (Schematic for Renard64 - document the board as it is now.)
- 03:18, 30 June 2007 Phil Short talk contribs uploaded File:Transformer pcb sch 002.GIF
- 03:15, 30 June 2007 Phil Short talk contribs uploaded File:Transformer pcb sch 002.GIF
