Search results
- Print Channel Configuration ...255 bytes (38 words) - 06:32, 29 January 2011
- **Print Channel Configuration ...1 KB (168 words) - 06:49, 29 January 2011
- **[[Print Channel Configuration]] ...1 KB (172 words) - 06:37, 29 January 2011
- Print Channel Configuration ...2 KB (210 words) - 06:37, 29 January 2011
- ...that I believe that the "touch up" phase of the process (after ironing the print onto the blank PCB) is understated in all the instructions I have found on ...in any direction) the software will reduce the size of the layout when you print. You can get past this "feature" of the software by printing a wide PCB lan ...11 KB (2,059 words) - 04:41, 29 January 2011
- Be sure to print it without any scaling. i.e. print at 1:1 by turning OFF the FIT TO PAGE or SCALE option which by default is ...s harbor freight ammo cans: [https://www.thingiverse.com/thing:3929289 3D print file]<br> ...7 KB (1,277 words) - 01:06, 11 November 2021
- Be sure when you print it, that it does not get scaled or the board components will not fit the en The cutout pattern for the Mobile unit is [[:media:Mobilepattern.pdf|here]]. Print it and cut it out along the line and place it on the inside of the enclosur ...7 KB (1,361 words) - 02:22, 29 January 2011
- ;Print channel configuration '''*''' ...4 KB (660 words) - 07:04, 29 January 2011
- The etch files are .pdf format. Be sure to print these with the ''actual size'' attributes set within Acrobat. ...15 KB (2,522 words) - 17:11, 5 April 2012
- The etch files are .pdf format. Be sure to print these with the ''actual size'' attributes set within Acrobat. ...15 KB (2,533 words) - 05:36, 11 October 2012
- The etch files are .pdf format. Be sure to print these with the ''actual size'' attributes set within Acrobat. ...16 KB (2,655 words) - 23:03, 29 May 2012
