Search results
  • [[File:File-import-LOR-HLS.png|350px|thumb|Figure 11-10]] *Click File, Import a LOR Sequence File. Then navigate and select the appropriate LOR sequence ...
    2 KB (248 words) - 03:57, 20 October 2013
  • ...Yes. Once OK has been clicked, the conversion will begin.<br />[[File:File-import-LOR-HLS.png]]<br /><br /> ...y converted into HLS. A prompt will appear to shutdown HLS to convert RGB channels (if any are present). ...
    2 KB (310 words) - 20:54, 7 March 2013
  • *[[Import]] *[[Import Channels]] ...
    709 bytes (86 words) - 06:31, 29 January 2011
  • **Creating new channels ...ur channel data, open the channel manager (''Manage Channels -> Manage Raw Channels''). ...
    4 KB (711 words) - 04:46, 24 March 2013
  • #Under the File menu, select ''Import a Vixen File''. – You will be prompted to select the VIX file. ...K, The conversion will take place and you will see a note showing that the channels have been converted. This may take some time. ...
    1 KB (195 words) - 03:59, 20 October 2013
  • ...A conversion of 600 channels takes about 3-4 minutes. A conversion of 3500 channels may take 20 minutes. There is a Vixen Conversion Channel Counter to give yo 4. After the conversion you can choose the Manage Channels tab, select channels to create a group and work like you normally would with HLS. See the beginn ...
    2 KB (289 words) - 20:54, 7 March 2013
  • **[[Import Channel Names List]] **Copy Channels ...
    1 KB (172 words) - 06:37, 29 January 2011
  • ...section of the wiki will discuss setting up channels, converting multiple channels into one, and how to use the RGB features for other display items. ====Adding RGB Channels==== ...
    5 KB (882 words) - 01:01, 24 March 2013
  • Import Channel Names List Copy Channels ...
    2 KB (210 words) - 06:37, 29 January 2011
  • ;Export and Import channel names list '''*''' ...a text file with a list of the channel names in the current sequence. The Import command takes a list in the same format (one channel per line) and imports ...
    4 KB (660 words) - 07:04, 29 January 2011
  • **Import Channel Names List **Create Channel Groups From Sequence Channels ...
    1 KB (168 words) - 06:49, 29 January 2011
  • HLS can import Audacity labels to help automate precise beat track creation. *Open Channel Manager (''Manage Channels -> Manage Raw Channels''). ...
    2 KB (374 words) - 01:00, 26 October 2013
  • * [http://www.youtube.com/watch?v=TDVOvs_0mUI Converting to RGB] - Converting channels to RGB. If you previously had ...om/watch?v=6Y8Y-Xx1WUc Folders and Fill] - Manage Channel Folders and Fill Channels ...
    9 KB (1,466 words) - 05:48, 20 October 2013
  • ...other than one has 'On/Off" on the rocker and the other is blank. When you import the BOM, make sure to delete the ones you do not want to use. I have a 8 pi ...ne side of the four switches together and this goes to the 'COM' lead. The channels for the connector are on the 'parts placement' picture. These switches don' ...
    7 KB (1,361 words) - 02:22, 29 January 2011
  • ...'''R'''ed, '''G'''reen and '''B'''lue. A string of 50 Pixels would use 150 channels in your [[Software|sequencing software]]. * '''Number of Channels''' - Most IC types can only control 3 channels, so you need 1 IC for each RGB Pixel if you want individual control. Other ...
    51 KB (7,006 words) - 18:57, 4 June 2022
  • ** Reverse order (ability to reorder the channels on a string so the most distant one is the first channel) '''PRICING DOES NOT INCLUDE SHIPPING, TAXES OR IMPORT DUTIES!''' ...
    36 KB (4,823 words) - 19:19, 4 June 2022
  • '''PRICING DOES NOT INCLUDE SHIPPING, TAXES OR IMPORT DUTIES!'''<br/> '''PRICING DOES NOT INCLUDE SHIPPING, TAXES OR IMPORT DUTIES!'''<br/> ...
    44 KB (6,727 words) - 16:05, 6 January 2018
  • ...view. The next step is for user to create export files from Nutcracker to import into Sequencing software on their PC. ...] This tool allows the user to create a profile in Vixen 2.1 of all of the channels needed for a RGB Pixel Megaree and also creates a 3D Priview model. The so ...
    25 KB (4,358 words) - 15:54, 15 August 2014
