Search results
  • :[[image:wiki - DMX (RJ-45) to Renard SS Connection.jpg|400px]] ==RJ's LYNX DMX DONGLE== ...
    982 bytes (142 words) - 03:49, 13 February 2011
  • <LI>Design uses the same rj-5 connector used in many of the DIYC designs. ...
    906 bytes (156 words) - 02:39, 29 January 2011
  • [[image:wiki - DMX (RJ-45) to Renard Connection.jpg | 600px]] ===DE9 to RJ-45 Adapter === ...
    18 KB (2,982 words) - 19:24, 7 November 2014
  • ...the different types of pixels available. (ie: GECE, WS2801, 6801, 3005, RJ Smart Strings, etc) ...
    4 KB (603 words) - 18:08, 5 August 2013
  • ...e your time and align and insert the pins first before you gently seat the RJ-45 lock lugs through each of their respective holes on the PCB. ...will connect between the parallel port of your controller PC and the β€˜IN’ RJ-45 socket on the LEDTRIKS. The PINOUTs are shown in the following table. ...
    17 KB (2,943 words) - 02:30, 18 August 2011
  • ...nGub21VSaQo4hG3D1Q%3d%3d 571-5556416-1]||19||J1-2, SSR Ports||align="left"|RJ 45 Top Entry ...
    10 KB (1,516 words) - 00:07, 6 November 2014
  • ...demonstration by [http://doityourselfchristmas.com/forums/member.php?56-RJ RJ]. ...
    11 KB (1,690 words) - 01:39, 7 February 2015
  • *[http://diylightanimation.com/wiki/index.php?title=Equipment#DMX_Devices RJ's LYNX DMX DONGLE] ...
    36 KB (4,823 words) - 19:19, 4 June 2022
  • [[image:wiki - DMX (RJ-45) to Renard SS Connection.jpg | 400px]] ...
    15 KB (2,365 words) - 03:42, 2 November 2013
  • The pin-out for the RJ-45 network cable is the same for all of the Sean Bowf derivative SSRs:<br>< ...
    15 KB (2,522 words) - 17:11, 5 April 2012
    15 KB (2,533 words) - 05:36, 11 October 2012
    17 KB (2,714 words) - 23:12, 10 May 2017
    17 KB (2,721 words) - 23:14, 10 May 2017
    16 KB (2,655 words) - 23:03, 29 May 2012
  • ...No status LEDs, inexpensive/simple to build. Developed by Robert Jordan (RJ). More info [[The GRINCH Controller | here]]. ;RJ-45 (or RJ45) : Registered Jack 45. A data plug or jack standard that allows ...
    29 KB (4,656 words) - 20:42, 29 April 2015
    15 KB (2,605 words) - 19:26, 28 July 2014
    15 KB (2,582 words) - 17:57, 21 March 2016
  • [[image:wiki - DMX (RJ-45) to Renard SS Connection.jpg | 500px]] ...
    27 KB (4,113 words) - 18:27, 9 July 2014
  • ...the inside top cover of your broadband case, consider using the side-entry RJ-45 jacks and a little longer cat5 cable instead of the top-entry version an ...
    21 KB (3,667 words) - 20:55, 7 September 2018
  • ...at each physical output can be re-wired to support either a "standard" DMX RJ-45 electrical output or a Renard electrical output without resorting to mak ...
    39 KB (6,655 words) - 11:38, 27 June 2018
