Bonjour,
Utilisateur d'une carte Arduino M?ga avec le logiciel Vixens depuis 1 an afin d'alimenter en On/OFF des guirlandes de Noel, je pr?vois de passer sur Xlight cette ann?e.
Or je n'arrive pas ? impl?menter ma configuration pass?e (et donc fonctionnelle sur Vixens) sur Xlight.
Pourriez vous m'aider svp ?
Voici le code televerser sur la carte Arduino
Good morning,
User of an Arduino Mega card with Vixens software for 1 year in order to power Christmas garlands on/off, I plan to switch to Xlight this year.
But I can't do it? implement my past configuration (and therefore functional on Vixens) on Xlight.
Could you help me please ?
Here is the code uploaded to the Arduino board
La configuration dans Vixens qui fonctionne est aussi fourni.
Merci de votre aide
Good morning,
Code:
#define MEGA_VIXEN
//#define UNO_VIXEN
#ifdef MEGA_VIXEN
#define MAX_CHANNELS 32
int channels[MAX_CHANNELS] = {2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33};
#endif
#ifdef UNO_VIXEN
#define MAX_CHANNELS 8
int channels[MAX_CHANNELS] = {2, 3, 4, 5, 6, 7, 8, 9};
#endif
#define POWER_UP_STATE HIGH //0 = Lights off at power up, 255 = lights on at power up
#define INACTIVITY_STATE LOW //0 = Lights off when inactive, 255 = lights on when inactive
#define INACTIVITY_TIMEOUT_MILLISECONDS (5UL * 1000UL) // 5 = 5 seconds, 1000 = 1000 milliseconds in a second
int incomingByte[MAX_CHANNELS];
unsigned long inactivityTimer;
void setup()
int i;
Serial.begin(9600); // set up Serial at 9600 bps
for ( i = 0; i < MAX_CHANNELS; i ++ )
pinMode(channels[i], OUTPUT);
digitalWrite(channels[i], POWER_UP_STATE);
inactivityTimer = millis();
void loop()
int i;
if (Serial.available() >= MAX_CHANNELS)
for (i = 0; i < MAX_CHANNELS; i ++) incomingByte[i] = Serial.read();
if ( (millis() - inactivityTimer) >= INACTIVITY_TIMEOUT_MILLISECONDS )
for ( i = 0; i < MAX_CHANNELS; i ++ ) incomingByte[i] = INACTIVITY_STATE;
for (i = 0; i < MAX_CHANNELS; i ++ ) digitalWrite(channels[i], ~incomingByte[i]);
Merci de votre aide
