Fort clarity. I hooked up 24 volt dc power supply + and - to v+ and grnd on board and used zues to drive data line.
What is zues ?
pixelnet Zues16 controller from DIYlightanimation. A little old but drives most of my 2811 pixels and and my 10watt Rob G floods at 12vots. I have a big mixture of controllers from renards, lynx, zues, Kostyn24. Zues controllers work at 12 volts so I am trying to use that for my data with the 24v power separate. My guess is I shouldn't have hooked up the v- from my 24vt power supply to the grnd on the flood.
thank you in advance for your help. Not yet. That is what I do with the 10 watt floods. Set up just like the wiki for the 10 watt floods as 12volts go in and out of the zuess. It's adding the 24volt seperat power that obviously has me confused a bit. If I run the ground (-) from the zues which is similar to what I would do from a falcon I think I'm not sure what I would do with the v- from the power supply. Or do I do nothing with that. I would be running the data and (-) ground from the zues and v+ from the power supply. Leaving the V- from the power unconnected or would that also be tied to the ground.
I've been through most of these posts and wondered if someone would be able to direct me right to a link for a board that can be used to control RGB floods with my ESPixels sticks?
Thanks
Bruce
Any flood that comes with a remote is likely not directly controllable in a light show. I think there might be some floods that use ws2811 but most are Bluetooth.
You can't directly directly control RGB floods from the esp nor can you directly use DMX fixtures. Both can be overcome with additional hardware.
You want to look for something that is explicitly ws281x based like this: https://www.aliexpress.com/item/1005001281828371.html?spm=2114.12010615.8148356.2.5f701c39c0GmCB
Nice find for less than $20.
PLUS Shipping: C$ 35.48 to Canada via Fedex IE
https://www.wallyslights.com/produc...542&utm_medium=email&utm_source=shopify_email
These are 12 volt
One of my Diy 24 volts floods. Quit on me after Halloween show so switched over to try these out .
Sent from my iPhone using Tapatalk
Buy them from RobG , he is a member here
