DIGWDF Gerber and DipTrace Design Files are now available for downloading. Here's what you need to know:
** There is a small charge for each file (Gerbers: $1, DipTrace: $2.50)
** The Gerber files are packed inside a ZIP archive file, which can be uploaded to most any board production house.
** The DipTrace design files require the installation of DipTrace PCB software, which is a free download from diptrace.com
** Where are the files? In the DIGWDF Store. Yes, the store is closed, but all the downloadable files are available, including our documentation and firmware listings. Make sure the email address listed in your store account is correct. After purchasing one or more files, the store will send an email with links to download the files you've chosen.
** If you want to view the Gerber files and/or print them out, we suggest the free gerbv tool (
https://sourceforge.net/projects/gerbv/) Once printed, you can measure them as sometimes the dimensions are necessary when you order PCBs.
Questions/Answers
1. Are these the actual DIGWDF files? Yes.
2. Can I make modifications to them? Yes, and if you do, you must remove any references to DIGWDF from the silkscreen layers.
3. Can I sell PCBs that I've had made? Yes, but DIGWDF cannot and will not support them. If you intend to sell them, you should download the DipTrace design files and remove any references to DIGWDF from the silkscreen layers and make your own Gerbers.
4. Can I post them on Oshpark or Tindie? Not the original DIGWDF files, no. But you can certainly modify the files, remove all references to DIGWDF and make them your own designs, and then do whatever you like with them at that point.
5. Can I copy the documentation files, too? If you modify the PCB in any way, no; you must write your own documentation for your version of the PCB, unless our original documentation specifies otherwise.
6. Can you help me make PCB modifications? No, sorry, but we'll be glad to answer questions you may have.
7. What if I can't get the email to download the files? Sorry, we can't help you with your email problems. Make sure
digwdf.com and
digwdf.org are allowed sources and are not blocked by your anti-spam software.
8. What if I delete the email with the download links? Don't do that until after you have downloaded the files.
