james70818
Master Rigger
So you see all the P10 Matrix and you want some!. You order a few from Ray Wu, get them in and now what! How do you build a backer board to mount them to? Lay it all out, drill the holes, cut access holes to get to the connectors..... Well Boscoyo Studio has a quick and easy solution for you. Introducing the Matrix Maker series of connectors.
The Matrix Makers are a series of T, X, and L shapes that allow you make an infinite number panel layouts. Here is what they look like:
Across the top you have connectors that allow you to hang the Matrix. The L's located in the top corners are universal left/right and utilize the existing alignment pins. The horizontal T in center also adds a hanger point.
In the middle row we have vertical T's on the ends and X in the center.
On the bottom the horizontal T without a hanger finishes up the layout.
One more addition to the P10 Matrix Maker series, the Power Clip. It is designed to hold both the Power Supply and a BeagleBone Black. Ignore the extra holes in the prototype. That was from a previous project.
All the connectors include the appropriate number machine screws. Pricing will follow. I need to run the numbers on how many will fit on a sheet now that I have machine times. The final production Matrix Maker clips will be black in color.
This is the first of a few projects we are working on for the P10's, stay tuned!
Thanks,
James
Thanks,
James
