When I made my P10 connectors from wood (not as nice) the ones on the edge I made extend 3/8" past the edge of panel. This allowed me to cut/route a grove in the wood enclosure to mount the whole assembly solidly minimizing the need for other hardware. It would be nice to have an option to have those connecting pieces extend to fit in a slot in enclosure. See photo.
Do you have a feel for how big of a matrix these brackets will handle. I see that you can put a hang point bracket between each pair of panels if necessary. So each mount point needs to only hold that column's weight. (Actually slightly less) so what's the breaking strength of those rigging points? You mentioned it's a thick material. How thick, and how close is the hang point to the edge?
--Jon Chuchla--
Sent from my iPhone using Tapatalk
I'm no stranger to large led walls. I typically hang them from box truss with 2 ton chain motors. I'm hanging an 18x32' wall in a few weeks for an event from a pair of telehandlers. (Those are those long reach forklift machines)
My line of questions goes to whether your line of accessories can make for a solid, low-budget video wall assembly.
--Jon Chuchla--
The only reason I'm skeptical is because I've never seen plastic used for rigging. It's almost always steel or heavy aluminum. Though given that plastics are very homogenous, I would expect their ratings to be rather predictable as well. You've peaked my interest. We use a 5:1 ratio for rigging hardware. That means the working load limit (WLL) is 1/5 of the breaking strength. I think I'm going to order some just to break them. I have access to the test rigs for this and I'm plenty curious.
--Jon Chuchla--
Sounds good if you look at the picture there are no screws or mounting holes the quarter inch piece of plywood fits into a slot and locks the panel in
Sent from my LGLS990 using Tapatalk
David, I can add another T that goes on the side with a hangar hole like the ones at the top. Then you could have mounting holes that extend beyond the panel to mount to a frame at every seam of the matrix.
Really pleased with the first run of Matrix Maker connectors. I bumped the thickness of the material up just to over engineer the plates. I have also redesigned a few things and planned ahead for a future reinforcement system. For most matrix sizes you will not need a reinforcement, the connectors are plenty strong enough.
You will see in the pictures a lot of machining is put into these plates for a clean professional install. The stainless machine screws are recessed into the plates and I'm extremely proud of how the Power Plate turned out with the integrated BBB mount.
Take a look:
Basic parts
Power Plate
4 wide by 5 tall matrix
Pricing is going to be roughly as follows:
The "L" or corner brackets with or without the hanger hole $2.00 for the pair
The "T" for vertical or horizontal applications with or without the hanger hole $2.00
The "X" or center connector $2.50
The Power Plate $7.00
So you can buy the Matrix Maker connectors (29 connectors) to build a 4 wide by 5 tall panel for $67.00 including the required stainless hardware.
These Matrix Maker connectors work with the current P10 panels being sold by Ray Wu. The P10 panels have 10 total M3 brass inserts. There are some other panels that have only 8 of the inserts. I have not confirmed the spacing yet for those panels. I have a couple panels being sent to me to work with and either adapt these connectors or make a new set for that style panel.
Thanks,
James
Well, Carpola. My panels only have 6 barrel inserts and are missing the critical portions that you have designed against. Looks like I will have to do this differently...
