Electronics Hardware
Revision as of 02:26, 22 February 2010 by Gmbartlett (talk | contribs) (Helix)
Links
SSR Direct Attach
Kit74
Hill320
Olsen 595/Grinch
Firegod
  • Documentation: Firegod
Renard
  • Documentation: Renard
Lynx
Helix
  • Documentation: Helix
Ledtriks
Triks-C
This is a an add on controller/process for the Ledtricks. One of the problems with the original LEDTRIKS design was the load placed on the PC to chunk the data out the parallel port. The TRIKS-C uses a ATMEL process to take a LEDSTRIKS file and send it out to the LEDTRIKS Controller, via the serial prot.
JEC Pixel Displays
  • Controlled through: DMX
rgbLED
TBA
Digital Input/Output Cards
