Electronics Hardware
Revision as of 15:13, 16 September 2010 by Dmcole (talk | contribs) (PIX-C)
Links
SSR Direct Attach
Kit74
Hill320
Olsen 595/Grinch
Firegod
  • Documentation: Firegod
Renard
  • Documentation: Renard
Lynx
Helix
  • Documentation: Helix
Ledtriks
One of the problems with the original LEDTRIKS design was the load placed on the PC to chunk the data out the parallel port. The TRICKS-C and the PIC-C controllers were created to address this shortcoming.
Triks-C
This is a an add on controller/process for the Ledtricks. The TRIKS-C uses a ATMEL process to take a LEDSTRIKS file and sends it out to the LEDTRIKS Controller, via the serial prot.
PIX-C
  • Controlled through: Serial port or standalone
  • Documentation: PIX-C
This is an add-on controller/processor for the Ledtricks. It is backward compatible with the TRIKS-C, and is based on the Microchip 16F688 processor.
JEC Pixel Displays
  • Controlled through: DMX
rgbLED
Digital Input/Output Cards
